Windows 7 and Watchdog timer
Zibeo
Post by Zibeo »
Is there an executable to enable, disable, and reset the watchdog timer in Windows 7 ?
Leonid
Re: Windows 7 and Watchdog timer
Post by Leonid »
The updated watchdog driver is attached.
Please, read readme.txt file before using the watchdog.
watchdog_pack.zip
(133.17 KiB) Downloaded 1216 times
Leonid Firdman
Zibeo
Post by Zibeo »
This driver (or the executable) doesn't appear to work. However the XP driver and executable seem to work on Win7. I tried both on fresh installs.
kaibab
Post by kaibab »
Is there an update to the Watchdog driver / executable on Windows 7. I can not get the above file to work on Windows 7 Pro.....
thank you,
Leonid
Post by Leonid »
The updated Watchdog driver for Win7 will be published soon.
Leonid Firdman
its1000
Post by its1000 »
Still no news for the win 7 watchdog driver ?
Leonid
Post by Leonid »
New Watchdog driver for Win7 is attached.
Please read carefully readme.txt file before installing and using the driver.
watchdog_2.1.zip
(192.59 KiB) Downloaded 1230 times
Leonid Firdman
its1000
Post by its1000 »
Thank you !
Zibeo
Post by Zibeo »
Did this latest watchdog app work for anyone? I've followed the directions and it doesn't work for me on a fresh install. Even when the watchdog is enabled in the bios it doesn't work after windows has been started up.
The test.bat does however work.
its1000
Post by its1000 »
At this time, I hadn't had time to test. I have to... Sorry.
Return to “Windows 7”
