Installing Ubuntu 10.04 on fitPC2 and fitPC2i
fly
Re: Installing Ubuntu 10.4 on fitPC2 and fitPC2i
Post by fly »
Well, just had a first look at it and I am not really an experted in xorg.foo, but despite some lvds, sdvo and hdmi erros, which are present in my log files, too, here is the one that currently bugs me:
(EE) PSB(0): First SDVO output reported failure to sync or input is not trainded!!!
FYI: LVDS is an internal connector mostly used for embedded displays like on notebooks. SDVO is a connector which can output quite some signals, e.g. HDMI/DVI. The latter one is used on the fitpc2 for the external displays.
Could you post your xorg.conf (/etc/X11/xorg.conf) and -- if possible -- try another display?
Works, thanks. Updating my initial post.
Thanks for reporting the error and tesing. I updated the first post with my howto with this information, too.
And the question of trustedness... :D
Well, on Ubuntu it is quite common to solve problems just like I did: "Add this ppa and install this file and maybe run that script" The problem is, that each user is resposnible for what he is doing. The user should know what software he is going to install.
usenet
Post by usenet »
fly wrote: Could you post your xorg.conf (/etc/X11/xorg.conf) and -- if possible -- try another display?
Fly, thanks for the continued support. This thing is really starting bugging me, but we will get it working.
I tried now the Ubuntu 9.10 version, which is a little better. I installed it according to the official procedure, and it works out of the box (well, almost, because I have no sound and some artifacts with video.) You can find the xorg.conf of the working 9.10 here: http://pastebin.com/vnBa5dE9
About 10.4 I don't have here a nonworking handy, but believe me I put it exactly like jsmaniac suggested in his post on Tue Aug 17, 2010 4:35 am. Of course with my values.
About trying another display. Unfortunately I don't have an easy way to do that, but I guess it is not a display issue, since it works so nice with 9.10.
My short term plans: fall back to 9.04 and try if video is still choppy. If yes, I don't know what to do maybe stay with Windows :(. I will also check the xorg.conf there and then redo all the installation for 10.04 and compare the two working xorg.confs and xorg.0.logs with the one from 10.04. I don't have anything else in mind.
Other question: is there a quick way to make the SPDIF out work under Linux? I have no sound...
fly
Post by fly »
You are using IEGD driver, not the PSB driver.
As 9.04 is nearing EndOfLIfe date, I would not recommend this. If 10.04 breaks, I would rather stay with 9.10 -- and try the psb driver there, it is known to work quite well -- till next year in the hope that we have a better support for lucid (and maverick!) by then. I keep my fingers crossed that Yves will have some spare time in the xmas holidays -- or hopefully even earlier -- so he can finish EXA-MIXED conversation. This is the last big NOGO for the psb driver an will likely resolve any remaining issues.
Uhm, as I don't have a fitPC2i, but only the first fitPC2, I don't have SPDIF and can't really help. Does alsa see the soundcard? If so, maybe it sees spdif and stereo out as two different soundcards? Just guessing... MAybe I have to get myself a fitPC2i someday... :)
manoka
Post by manoka »
fly wrote:1. Install Ubuntu 10.04
I bought my Fit-PC 2i without HDD. Now with a WD Scorpio Blue HDD connected, my installation goes to maximum 50% of the process (in other trials to less than that), then an error keeps occuring, of which I don't know the reason. The installation CD works fine on a laptop PC.
I would appreciate very much some help!
manoka
fly
Post by fly »
Well, without further information, I am once again just guessing..
You could check /var/log/installer/ for installation log files and maybe there are errors logged which provide more detailed information. I don't know if that is the correct log location, I am just guessing by name :) Maybe ubuntu even opens an emergency shell on one of the virtual terminals (ctrl + alt + function key).
You could try to use the disk in another computer, install ubuntu and then swap it.
You could try to install ubuntu 9.10 to see if it's a lucid issue.
You could try to install from alternate installation cd / text mode.
Is this a revision 1.1?
manoka
Post by manoka »
fly wrote:Is this a revision 1.1?
This is the official desktop installation CD, which I got a few weeks ago from https://shipit.ubuntu.com.
fly
Re: Installing Ubuntu 10.04 on fitPC2 and fitPC2i
Post by fly »
I was referring to the revision of the fitPC2i. First revision had some problems with HDD iirc. There's a thread about this issue including a patched kernel and lucid-server iso. I don't know if that'S really targeting your problem, but you might want to have a look. Again, without detailed information, it's hard to guess what might cause (or solve) the problem.
mickster04
Post by mickster04 »
I just tryed a clean install of 10.04 using the instructionson the fisrt post, I get as far as installing the patched psb drivers and all's I get is a blank screen. I haven't checked to see if the compulab xorg file makes a difference, but when I upgraded (from 9.10), it didn't.
what would happen if i followed the 9.10 instructions using 10.04?
fly
Post by fly »
It should make a difference, because without you will most likely not be able to get X up.
You will run into version mismatches. The packages are not built for lucid and are built against other library, kernel and xorg versions. The custom-kernel included in the 9.10 install will most likely not work.
jeanmark
Post by jeanmark »
I installed ubuntu 10.04 as in this thread, but after instaling poulsbo drivers, and configure xorg.conf my Philips LCD TV 37PFL7603D_10 reports "This video format is not supported":
I try different modeline settings, and nothing works. If worked with Windows XP and Windows vista in full HD resolution. It works with my Mac Book.
From my MacBook i got EDID (at the end of post). It also propose me some modeline settings, I tryed this, but it does not help. When I do startx I got:
X.Org X Server 1.7.6
Release Date: 2010-03-17
X Protocol Version 11, Revision 0
Build Operating System: Linux 2.6.24-28-server i686 Ubuntu
Current Operating System: Linux mali 2.6.32-26-generic #48-Ubuntu SMP Wed Nov 24 09:00:03 UTC 2010 i686
Kernel command line: BOOT_IMAGE=/boot/vmlinuz-2.6.32-26-generic root=UUID=a11e3448-f0ab-412b-9886-c11eaf7ad72b ro quiet splash
Build Date: 10 November 2010 11:25:26AM
xorg-server 2:1.7.6-2ubuntu7.4 (For technical support please see http://www.ubuntu.com/support)
Current version of pixman: 0.16.4
Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: Sat Dec 18 23:35:54 2010
(==) Using config file: "/etc/X11/xorg.conf"
(==) Using config directory: "/usr/lib/X11/xorg.conf.d"
(EE) PSB(0): the stolenBase is:0x3f800000
(EE) PSB(0): screnIndex is:0;fbPhys is:0x3f800000; fbsize is:0x007df000
xf86TokenToOptinfo: table is NULL
Xpsb - 5.0.1.0046
(EE) PSB(0): has_fbdev is true
EXA bug: pPixmap->devPrivate.ptr was 0xb6ef4000, but should have been NULL.
DDC block report generated by SwitchResX version 4.2 for display
Philips FTV
------------------- RAW DATA ------------------------
0 1 2 3 4 5 6 7 8 9 A B C D E F
0 | 00 FF FF FF FF FF FF 00 41 0C 00 00 01 01 01 01
1 | 30 11 01 03 80 40 24 78 0A E6 92 A3 54 4A 99 26
2 | 0F 4A 4C 21 08 00 8B C0 01 01 01 01 01 01 01 01
3 | 01 01 01 01 01 01 02 3A 80 D0 72 38 2D 40 10 2C
4 | 45 80 80 68 21 00 00 1E 01 1D 80 3E 73 38 2D 40
5 | 7E 2C 45 80 80 68 21 00 00 1E 00 00 00 FC 00 50
6 | 68 69 6C 69 70 73 20 46 54 56 0A 20 00 00 00 FD
7 | 00 30 3E 0F 46 0F 00 0A 20 20 20 20 20 20 01 6D
0 | 02 03 32 F1 52 1F 10 20 21 22 14 05 13 04 12 03
1 | 11 02 16 07 15 06 01 29 09 1F 07 15 07 50 19 07
2 | 86 83 01 00 00 6C 03 0C 00 40 00 00 00 C0 10 01
3 | 10 01 01 1D 80 D0 72 1C 16 20 10 2C 25 80 80 68
4 | 21 00 00 9E 01 1D 00 BC 52 D0 1E 20 B8 28 55 40
5 | 80 68 21 00 00 1E 8C 0A D0 90 20 40 31 20 0C 40
6 | 55 00 80 68 21 00 00 18 8C 0A D0 90 20 40 31 20
7 | 0C 40 55 00 90 2C 11 00 00 18 00 00 00 00 00 B2
< 00FFFFFF FFFFFF00 410C0000 01010101 30110103 80402478 0AE692A3 544A9926 0F4A4C21 08008BC0 01010101 01010101 01010101 0101023A 80D07238 2D40102C 45808068 2100001E 011D803E 73382D40 7E2C4580 80682100 001E0000 00FC0050 68696C69 70732046 54560A20 000000FD 00303E0F 460F000A 20202020 2020016D 020332F1 521F1020 21221405 13041203 11021607 15060129 091F0715 07501907 86830100 006C030C 00400000 00C01001 1001011D 80D0721C 1620102C 25808068 2100009E 011D00BC 52D01E20 B8285540 80682100 001E8C0A D0902040 31200C40 55008068 21000018 8C0AD090 20403120 0C405500 902C1100 00180000 000000B2 >
{ 0x00, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x00, 0x41, 0x0C, 0x00, 0x00, 0x01, 0x01, 0x01, 0x01, 0x30, 0x11, 0x01, 0x03, 0x80, 0x40, 0x24, 0x78, 0x0A, 0xE6, 0x92, 0xA3, 0x54, 0x4A, 0x99, 0x26, 0x0F, 0x4A, 0x4C, 0x21, 0x08, 0x00, 0x8B, 0xC0, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x02, 0x3A, 0x80, 0xD0, 0x72, 0x38, 0x2D, 0x40, 0x10, 0x2C, 0x45, 0x80, 0x80, 0x68, 0x21, 0x00, 0x00, 0x1E, 0x01, 0x1D, 0x80, 0x3E, 0x73, 0x38, 0x2D, 0x40, 0x7E, 0x2C, 0x45, 0x80, 0x80, 0x68, 0x21, 0x00, 0x00, 0x1E, 0x00, 0x00, 0x00, 0xFC, 0x00, 0x50, 0x68, 0x69, 0x6C, 0x69, 0x70, 0x73, 0x20, 0x46, 0x54, 0x56, 0x0A, 0x20, 0x00, 0x00, 0x00, 0xFD, 0x00, 0x30, 0x3E, 0x0F, 0x46, 0x0F, 0x00, 0x0A, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x01, 0x6D, 0x02, 0x03, 0x32, 0xF1, 0x52, 0x1F, 0x10, 0x20, 0x21, 0x22, 0x14, 0x05, 0x13, 0x04, 0x12, 0x03, 0x11, 0x02, 0x16, 0x07, 0x15, 0x06, 0x01, 0x29, 0x09, 0x1F, 0x07, 0x15, 0x07, 0x50, 0x19, 0x07, 0x86, 0x83, 0x01, 0x00, 0x00, 0x6C, 0x03, 0x0C, 0x00, 0x40, 0x00, 0x00, 0x00, 0xC0, 0x10, 0x01, 0x10, 0x01, 0x01, 0x1D, 0x80, 0xD0, 0x72, 0x1C, 0x16, 0x20, 0x10, 0x2C, 0x25, 0x80, 0x80, 0x68, 0x21, 0x00, 0x00, 0x9E, 0x01, 0x1D, 0x00, 0xBC, 0x52, 0xD0, 0x1E, 0x20, 0xB8, 0x28, 0x55, 0x40, 0x80, 0x68, 0x21, 0x00, 0x00, 0x1E, 0x8C, 0x0A, 0xD0, 0x90, 0x20, 0x40, 0x31, 0x20, 0x0C, 0x40, 0x55, 0x00, 0x80, 0x68, 0x21, 0x00, 0x00, 0x18, 0x8C, 0x0A, 0xD0, 0x90, 0x20, 0x40, 0x31, 0x20, 0x0C, 0x40, 0x55, 0x00, 0x90, 0x2C, 0x11, 0x00, 0x00, 0x18, 0x00, 0x00, 0x00, 0x00, 0x00, 0xB2, }
Valid EDID block: checksum passed
------------------- MAIN EDID BLOCK -----------------
EDID Version........1.3
Manufacturer........PHL
Product Code........0 (0000) (0000)
Serial Number.......01010101
Manufactured........Week 48 of year 2007
Max H Size..........64 cm
Max V Size..........36 cm
Gamma...............2.20
Display Supported Features:
Display type:
RGB 4:4:4 & YCrCb 4:4:4 Color Encoding Formats
Display is non continuous frequency
Default color space is not sRGB standard
Preferred timing mode includes Native Pixel Format
Input signal & sync:
Digital Input
Color Bit Depth is undefined
Digital Interface is not defined
Color info:
Red x = 0.640 Green x = 0.290 Blue x = 0.150 White x = 0.289
Red y = 0.330 Green y = 0.600 Blue y = 0.060 White y = 0.299
Established Timings:
640 x 480 @ 60Hz
800 x 600 @ 60Hz
1024 x 768 @ 60Hz
Manufacturer Reserved Timings:
Standard Timing Identification:
#0: 1360 x 765 @ 60Hz (8BC0)
Monitor Description blocks:
Descriptor #0 - Timing definition:
Mode = 1920 x 1080 @ 50.000Hz
Pixel Clock............. 148.50 MHz Non-Interlaced
Horizontal Vertical
Active.................. 1920 pixels 1080 lines
Front Porch............. 528 pixels 4 lines
Sync Width.............. 44 pixels 5 lines
Back Porch.............. 148 pixels 36 lines
Blanking................ 720 pixels 45 lines
Total................... 2640 pixels 1125 lines
Scan Rate............... 56.250 kHz 50.000 Hz
Image Size.............. 640 mm 360 mm
Border.................. 0 pixels 0 lines
Sync: Digital separate with
* Positive vertical polarity
* Positive horizontal polarity
Descriptor #1 - Timing definition:
Mode = 1920 x 1080 @ 24.000Hz
Pixel Clock............. 74.25 MHz Non-Interlaced
Horizontal Vertical
Front Porch............. 638 pixels 4 lines
Blanking................ 830 pixels 45 lines
Total................... 2750 pixels 1125 lines
Scan Rate............... 27.000 kHz 24.000 Hz
Descriptor #2 - Monitor name:
Philips FTV
Descriptor #3 - Monitor limits:
Horizontal frequency range.......15-70 kHz
Vertical frequency range.........48-62 Hz
Maximum bandwidth unspecified
------------ EXTENSION EDID BLOCK 1 ---------------
CEA-EXT: CEA 861 Series Extension:
Revision:..............................3
First DTD block at offset..............46
Display Supports:
overscan
basic audio
YCbCr 4:4:4
YCbCr 4:2:2
Data Block Collection:......1
Video Type: standard CEA Timings
#1: 1920 x 1080p @ 50Hz - 16:9 - '1080p50' is not native (31)
#2: 1920 x 1080p @ 59.94/60Hz - 16:9 - '1080p' is not native (16)
#3: 1920 x 1080p @ 23.98/24Hz - 16:9 - '1080p24' is not native (32)
#4: 1920 x 1080p @ 25Hz - 16:9 - '1080p25' is not native (33)
#5: 1920 x 1080p @ 29.97/30Hz - 16:9 - '1080p30' is not native (34)
#6: 1920 x 1080i @ 50Hz - 16:9 - '1080i25' is not native (20)
#7: 1920 x 1080i @ 59.94/60Hz - 16:9 - '1080i' is not native (5)
#8: 1280 x 720p @ 50Hz - 16:9 - '720p50' is not native (19)
#9: 1280 x 720p @ 59.94/60Hz - 16:9 - '720p' is not native (4)
#10: 720 x 576p @ 50Hz - 16:9 - '576pH' is not native (18)
#11: 720 x 480p @ 59.94/60Hz - 16:9 - '480pH' is not native (3)
#12: 720 x 576p @ 50Hz - 4:3 - '576p' is not native (17)
#13: 720 x 480p @ 59.94/60Hz - 4:3 - '480p' is not native (2)
#14: 720(1440) x 576i @ 50Hz - 16:9 - '576iH' is not native (22)
#15: 720(1440) x 480i @ 59.94/60Hz - 16:9 - '480iH' is not native (7)
#16: 720(1440) x 576i @ 50Hz - 4:3 - '576i' is not native (21)
#17: 720(1440) x 480i @ 59.94/60Hz - 4:3 - '480i' is not native (6)
#18: 640 x 480p @ 59.94/60Hz - 4:3 - 'DMT0659' is not native (1)
Data Block Collection:......2
Audio Type - not interpreted
Data Block Collection:......3
Speaker allocation - not interpreted
Data Block Collection:......4
Found HDMI 1.3a IEEE Registration Identifier
Detailed Timing Blocks - 1 is native
Detailed Timing Block #1 - Timing definition:
Mode = 1920 x 540 @ 50.044Hz
Pixel Clock............. 74.25 MHz Interlaced
Horizontal Vertical
Active.................. 1920 pixels 540 lines
Front Porch............. 528 pixels 2 lines
Back Porch.............. 148 pixels 15 lines
Blanking................ 720 pixels 22 lines
Total................... 2640 pixels 562 lines
Scan Rate............... 28.125 kHz 50.044 Hz
Detailed Timing Block #2 - Timing definition:
Mode = 1280 x 720 @ 50.000Hz
Horizontal Vertical
Active.................. 1280 pixels 720 lines
Front Porch............. 440 pixels 5 lines
Sync Width.............. 40 pixels 5 lines
Back Porch.............. 220 pixels 20 lines
Blanking................ 700 pixels 30 lines
Total................... 1980 pixels 750 lines
Scan Rate............... 37.500 kHz 50.000 Hz
Detailed Timing Block #3 - Timing definition:
Mode = 720 x 576 @ 50.000Hz
Pixel Clock............. 27.00 MHz Non-Interlaced
Horizontal Vertical
Active.................. 720 pixels 576 lines
Front Porch............. 12 pixels 5 lines
Sync Width.............. 64 pixels 5 lines
Back Porch.............. 68 pixels 39 lines
Blanking................ 144 pixels 49 lines
Total................... 864 pixels 625 lines
Scan Rate............... 31.250 kHz 50.000 Hz
* Negative vertical polarity
* Negative horizontal polarity
Detailed Timing Block #4 - Timing definition:
Horizontal Vertical
Image Size.............. 400 mm 300 mm
How can I make this to work?
Return to “Ubuntu 10.04”
