640x480 @ 60Hz displayed as 656x496 @ 60Hz
danvitek
Post by danvitek »
With display setting 640x480 60HZ, the outputted format is actually 656x496 60Hz.
XP SP3 with the latest GMA500 6.14.11.1016
I need exactly 640x480 for my LCD panel.
72Hz has the same problem. 75Hz is OK but my panel(controller) does not accept 75Hz.
Tried to install xp-display-iegd-10_1-090719 without success.
Wonder if that will cure the problem?
Any other suggestions?
AoRaToS
Re: 640x480 @ 60Hz displayed as 656x496 @ 60Hz
Post by AoRaToS »
Did you remove the GMA driver before attempting to install IEGD?
danvitek
Post by danvitek »
your question solved my problem.
Uninstalling the GMA driver and using the standard driver in XP allowed me to run 640x480 @ 60Hz.
AoRaToS
Post by AoRaToS »
Glad it worked for you!
Return to “Display driver”
