display question
smiguy
display question
Post by smiguy »
I'm having issues connecting my fit-pc to my Samsung SyncMaster LCD monitor. It appears that the video signal is getting to the LCD, but it immediately goes into low power mode. Using the same cable I can get the video to display on my Samsung CRT television from the fit-pc. Additionally, my LCD is capable of displaying a picture with my DVD player.
So the situation is, I know that the fit-pc is outputting video and that my LCD is capable of receiving dvi video. But when I put the two together nothing.
Here are some ideas that I've thought of and would like some feedback from the community.
1) Upgrade my single link DVI cable to a dual link one. Rational, I think the signal may be stronger.
2) Get the HDFury and convert to a VGA signal.
3) Buy something that can boost the signal.
4) Get another LCD w/DVI and hope it plays nice with the fit-pc.
5) Assume the fetal position.
AoRaToS
Re: display question
Post by AoRaToS »
I would try another cable first. If you know someone else with a fit-PC2 try that with your TV also to rule out any problems with your fit-PC2 as I read somewhere on the forum something about a problem with the signaling or so, probably rare...Also I've read about similar problems that were solved by using a repeater... I'd suggest borrowing one first before going out and buying things that might not solve your problem...
Check if the BIOS settings screen displays OK.
Connect a powered-off fit-PC2 to your display turned-on, power fit-PC2 while pressing 'F2'.
This should display at VGA mode regardless of any handshake between the display and fit-PC2.
Irad Stavi
Forum admin
smiguy
Post by smiguy »
Thanks for the suggestions.
I tried booting to the BIOS screen and still nothing on my Samsung LCD. I did bring my fit-pc into work and was able to get the display working on a Dell LCD.
So something is up with my Samsung....but yet I still get video over DVI with my DVD player.
I think my only hope with the Samsung LCD is an inline repeater to boost the signal.
dgux
Post by dgux »
I can see BIOS and GRUB just fine but nothing from xorg. Any thoughts how how I can get some video on my Philips plasma TV?
Return to “Display interface”
