SATA/PATA converter is wired to Fit-PC2 motherboard and included in all Fit-PC2 variants (diskless as well).docbee wrote:What connector do I get when ordering the diskless modell? SATA or PATA? Is the SATA/PATA converter included in the diskless variant?
SATA/PATA
Re: SATA/PATA
Re: SATA/PATA
My HDD is detected as "ad0: 38154MB <FUJITSU MHW2040BH 00000012> at ata0-master UDMA33".
Is UDMA33 a limitation of a PATA -> SATA converter?
Tobe
Tobe
Re: SATA/PATA
What operating system you installed? The limit of the converter is UDMA100.
Re: SATA/PATA
Hi yogev_ezra,
Thanks for your answer, i'm going to check this!
I've installed FreeBSD 7.2 (my FitPC2 is my headless home server).
Re: SATA/PATA
Can you go to BIOS and see what mode the hard disk is in?
Reboot the machine, then press F2 to enter BIOS.
It's in the first BIOS screen - you see a line with hard disk name.
Press Enter to go inside it, and then post here what is written there.
Re: SATA/PATA
I can't go to BIOS because it's running headless and i don't have any screen handy
Don't mind, i'll try to switch to UDMA100 by hand, just to see if it works.
