can it support 1920x1200?
I have a 24' (1920x1200) LCD with DVI-D. Can fit-pc2 work with it?
Re: can it support 1920x1200?
I try to connect fit-pc2 to my plasma Panasonic 42px80E with max resolution 1024x768 through hdmi.
http://www.panasonic.it/html/it_IT/Prod ... kInfo=true
Ubuntu pre-installed seems start ok but when X Server start after Ubuntu Splash Screen, the screen become blank (black).
What's wrong?
What's the pre-configured resolution in Ubuntu?
What's wrong?
Hi.
The Full-HD format of TVs is 1920x1080, not all chipsets support that.
Regards.
Regards.
What's the maximum resolution that the Fit-PC2 can support?
Pixel clock on SDVO interface is 160MHz. That should be the limiting factor.
1920x1200@60Hz is confirmed to work. I have no indications on higher resolutions.
I think you meant, 1920x1200 (as 1900x1200 is not a standard resolution)
Thanks for the feedback!![Smile :)](./images/smilies/icon_e_smile.gif)
I had my Fit-PC2 connected to 30" Dell, with native resolution of 2560x1600, however Fit-PC2 allowed setting at most 1920x1200.irads wrote:1920x1200@60Hz is confirmed to work. I have no indications on higher resolutions.
2560x1600@60Hz requires a pixel clock of 245MHz. fit-PC2 supports up to 160MHz.
