End-users,
Feel free to reply with information on your memory SO-DIMM(s), known to work or not.
Please specify which fitlet model, and enough details about your memory SO-DIMM(s)
for someone else to purchase.
If you have measured speed results, please add.
Please don't post results of SO-DIMM(s) that by specification won't work. Meaning a
DDR2 or DDR4 won't work, only DDR3. Same for 16GB, (or larger), modules, fitlet supports
upto 8GB, not beyond.
Here is the memory SO-DIMM I have used successfully;
My fitlet model - fitlet-iA10
Vendor - Kingston
Model - HX316LS9IB/8
Size - 8GB
Speed - 1333MHz, 8-8-8
Voltage - dual 1.35V/1.5V
Memory SO-DIMMs - Used or tried by customers
Arwen Evenstar
Rivendale, Middle Earth
Re: Memory SO-DIMMs - Used or tried by customers
Crucial CT102464BF160B - see http://www.crucial.com/usa/en/ct102464bf160b - works
added (inspired by Arwen): on filtlet-X v1.1
Worked successfully on Fitlet-B:
Micron 2 GB DDR3L (MT8KTF25664HZ-1G6M1)
Moved my SO-DIMM from my fitlet-iA10 to my fitlet-H. Works fine.
My fitlet model - fitlet-H
Vendor - Kingston
Size - 8GB
Vendor - Kingston
Size - 8GB
Arwen Evenstar
Ordered a matched pair of new DIMMS for my fitlet-H. Works great, (especially the
memory interleaving).
Vendor - Kingston
Model - HX318LS11IBK2/16
Size - 2 x 8GB
Vendor - Kingston
Size - 2 x 8GB
Arwen Evenstar
My fitlet model - Mint Box Mini
Vendor - G.Skill
Model - F3-1600C11S-8GSL
Size - 8GB (8192MB)
Speed - DDR3-1600 PC3-12800
Voltage - 1.35V
Note: although stated speed is 1600 seller assures me it is 'backward compatible" with 1333 and is working fine in Mint Box Mini.
Additional info as printed on package:
CL11-11-11-28 So-Dimm
Original MBM 4GB RAM is working in a Fitlet B.
Vendor - G.Skill
Size - 8GB (8192MB)
Voltage - 1.35V
KVR16LS11/8, KVR16LS11/4 can be used in IPC/IPC2 FitPC3/3i/4 and all Fitlet.
http://www.kingston.com/dataSheets/KVR16LS11_8.pdf
http://www.kingston.com/dataSheets/KVR16LS11_4.pdf
