I received my FIT-PC2 thursday and got it up and running without any problems, but yesterday when I was surfing the colour green went missing. I've changed the HDMI-cable going to my TV (Samsung A866) but green is still missing.
Does anyone have any idea what the problem might be?
I also have the problem that when the HDMI cable is connected to the TV some channels lose the signal and goes black, when I pull out the PC-cable the TV-picture comes back ok.
Dalf
Colour gone missing
Re: Colour gone missing
Green goes on one of the differential pairs of the DVI-D interface. Signal on this pair is lost between the fit-PC2 and your TV.
Since you checked with another cable we can rule-out the cable.
To double check
- try fit-PC2 with another HDMI input on your TV or try fit-PC2 with another display using the HDMI to DVI adapter.
If there is no green - there is a problem with fit-PC2, contact rma@fit-pc.com. Otherwise the problem is with the HDMI port of the TV.
To double check
Hi irads,
Thanks for the reply. I've tried the HDMI ports on the TV but get no picture at all, only the HDMI/DVI port worked. I'll try to find another display at my place of work tomorrow and see if it works there. /Dalf
Hi irads!
Finally I got to a display after 3 days that I could plug my PC to. The good news is for the FIT-PC2, the colours were correct and everything looked good.
It was a Samsung TV that I got to test the PC on, which means that it is the connection to my TV that must be a fault. The TV-picture and when I connect my laptop via VGA, the colours are correct, so something must be the matter with the HDMI/DVI connection.
Wish me luck with Samsung!
Regards
Dalf
Regards
Dalf
