Audio device?
faceless
Audio device?
Post by faceless »
Hi all
Has anyone managed to get audio working from Linux? I have alsa installed, every channel unmuted and have run speaker-test on every device in the system but no sound. I have a standard 3.5mm jack plugged into the socket just outside of the power connector, and this is under recent Ubuntu.
Any ideas?
Re: Audio device?
What is the OS do you use? Is it Linux Mint, Ubuntu, or some other Linux distributions?
faceless
Re: Audio device?
Post by faceless »
Hi Gabriel - thanks for getting back. It's Ubuntu 12.10.
Linux fit 3.5.0-21-generic #32-Ubuntu SMP Tue Dec 11 18:51:59 UTC 2012 x86_64 x86_64 x86_64 GNU/Linux
Re: Audio device?
I suggest you to install the pulseaudio utility and to choose the coresponding profile to your output desire (analog/HDMI)
vtailor
Re: Audio device?
Post by vtailor »
You run 'aplay -l' and discover that the sound device is called SB:
bash-4.2# aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: Generic [HD-Audio Generic], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 1: SB [HDA ATI SB], device 0: ALC888 Analog [ALC888 Analog]
Subdevices: 0/1
card 1: SB [HDA ATI SB], device 1: ALC888 Digital [ALC888 Digital]
Subdevices: 1/1
bash-4.2
You then can get the following /etc/asound.conf:
pcm.Generic { type hw; card Generic; }
ctl.Generic { type hw; card Generic; }
pcm.SB { type hw; card SB; }
ctl.SB { type hw; card SB; }
pcm.!default pcm.SB
ctl.!default ctl.SB
You then run alsamixer and adjust it to raise the volumes of < Master > and < Front > equally, and save the result as 'alsactl save'.
Result: Gorgeous sound.
vtailor
Re: Audio device?
Post by vtailor »
However, chasing HDMI operation in Linux leads to a bugzilla bug page in which it becomes clear that AMD has HDMI problems with related chipsets. One user suggested unplugging the HDMI cable, then re-plugging it to get HDMI working. I'll tell you in advance that does not work on the T-40N in the fit-pc3 basic, but you do get some interesting sounds through the HDMI connection in the process. Herewith, unplug and re-plug the HDMI cable as a shell script doxrandrswitch.sh:
xrandr --output HDMI-0 --off
xrandr --auto
followed by dmesg | tail:
bash-4.2# sh doxrandrswitch.sh
bash-4.2# dmesg | tail
[ 1334.652240] Raw EDID:
[ 1334.652244] 00 ff ff ff ff ff ff 00 04 69 fd 22 03 01 01 01
[ 1334.652247] 10 17 01 03 80 30 1b 78 2a 2a c5 a4 56 4f 9e 28
[ 1334.652251] 03 ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
[ 1334.652254] ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
[ 1334.652257] ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
[ 1334.652260] ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
[ 1334.652263] ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
[ 1334.652265] ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
[ 1334.653500] [drm:radeon_dvi_detect] *ERROR* HDMI-A-1: probed a monitor but no|invalid EDID
bash-4.2#
You do hear a click though.
vtailor
Re: Audio device?
Post by vtailor »
I downloaded the latest fglrx from AMD directly and installed it on my Slackware fit-pc3 partition. At the moment, I am having no-problem HDMI sound from the xmms music player, and will no doubt get flash to follow soon.
There is a "recent" article in Phoronix to the effect that the author of the radeon.ko kernel module deliberately shut HDMI off, and he is "considering" re-enabling it. Until then, the generic kernel modules and X drivers will not produce HDMI sound, and you need to resort to installing fglrx.
P. S. This is a 32-bit box, the 64-bit version was ruining the hard drive.
Return to “Linux on fit-PC3”
