EMGD 1.16 driver on Linux Mint 13 MATE
BuZz
Re: EMGD 1.16 driver on Linux Mint 13 MATE
Post by BuZz »
ok thanks for the info. what was changed in regarding to the bug mentioned a few posts up you said was fixed ? it was the dkms config ?
Denis
Post by Denis »
Yes, it was necessary to set the correct KERNELVER parameter in dkms.conf.
Compulab's Linux support
BuZz
Post by BuZz »
ftoth
Post by ftoth »
EMGD 1.16.3228 has just been released by Intel on their web site.
Ferry
wrc4
Post by wrc4 »
Code:
deb http://archive.ubuntu.com/ubuntu/ maverick-updates main restricted universe multiverse
This failed when doing apt-get update. Looks like ubuntu has removed the maverick stuff from their archive. Is there a workaround? Why is it needed to downgrade xorg?
Denis
Post by Denis »
Xserver-xorg to must be downgraded to 1.9 version because of emgd 1.16 driver requirments. It's just crashes if we use more recent xserver version.
Use 76.73.4.58/ubuntu/ instead of archive.ubuntu.com/ubuntu/
deb http://76.73.4.58/ubuntu/ maverick-updates main restricted universe multiverse
wrc4
Post by wrc4 »
Thanks. It works now.
lakano
Post by lakano »
Hello everybody ! :-)
I'm trying since many weeks now, to use EMGD on my Acer Aspire One AO751h, and I would known if someone could help me before I put this laptop to the trash ! ^^
I have found your solution for Fit PC, and I have read that we could try on Ubuntu 12.10.
So, I have downgrade xorg, and used your deb packages. I have blacklisted psb/gma500 modules, and added a redirection script for X (because of the "-background" option renamed "-nr").
I have found the exact resolution parameters (for the native 1366x768 resolution), and I have no errors (EE), warnings (WW), failed messages or others problems in the logs.
But, strangly, I still have a blank screen .... :(
Here is my xorg.conf :
Section "ServerLayout"
        Identifier     "X.org Configured"
        Screen          "Screen0"
EndSection
Section "Monitor"
        Identifier   "Monitor0"
        VendorName   "Monitor Vendor"
        ModelName    "Monitor Model"
#       Modeline "1366x768x60"  72.30  1366 1413 1445 1525  768 770 775 789 -HSync +VSync
#       HorizSync       60
#       VertRefresh     60
#       Option          "DPMS"
EndSection
Section "Device"
    Identifier "Card0"
    Driver     "emgd"
    VendorName "Intel(R) DEG"
    BoardName  "Embedded Graphics"
    BusID      "0:2:0"
    Screen      0
    Option     "PcfVersion"            "1792"
    Option     "ConfigId"              "1"
    Option     "ALL/1/name"                   "LVDS"
    Option     "ALL/1/General/PortOrder"      "40000"
    Option     "ALL/1/General/DisplayConfig"  "1"
    Option     "ALL/1/General/DisplayDetect"  "1"
    Option     "ALL/1/General/swcursor"       "0"
    Option     "ALL/1/General/Accel"          "1"
    Option     "ALL/1/General/shadowfb"       "1"
    Option     "ALL/1/General/tearfb"         "0"
    Option     "ALL/1/General/xVideo"         "1"
    Option     "ALL/1/General/XVideoBlend"    "0"
    Option     "ALL/1/General/DRI"            "1"
    Option     "ALL/1/General/DRI2"             "1"
    Option     "ALL/1/General/Refresh"    "60"
    Option     "ALL/1/General/EnableRegOverride" "1"
    Option     "ALL/1/General/DispARB"           "0x00003232"
    Option     "ALL/1/Port/4/General/name"           "LVDS"
    Option     "ALL/1/Port/4/General/EdidAvail"      "0"
    Option     "ALL/1/Port/4/General/EdidNotAvail"   "5"
    Option     "ALL/1/Port/4/General/Rotation"       "0"
    Option     "ALL/1/Port/4/General/Edid"           "0"
    Option     "ALL/1/Port/4/General/CenterOff"      "1"
    Option     "ALL/1/Port/4/General/MultiDvo"       "0"
    Option     "ALL/1/Port/4/FpInfo/BkltMethod"      "1"
    Option     "ALL/1/Port/4/FpInfo/BkltT1"          "60"
    Option     "ALL/1/Port/4/FpInfo/BkltT2"          "200"
    Option     "ALL/1/Port/4/FpInfo/BkltT3"          "200"
    Option     "ALL/1/Port/4/FpInfo/BkltT4"          "50"
    Option     "ALL/1/Port/4/FpInfo/BkltT5"          "400"
    Option     "ALL/1/Port/4/Dtd/1/PixelClock"       "54720" #"72300"
    Option     "ALL/1/Port/4/Dtd/1/HorzActive"       "1366"
    Option     "ALL/1/Port/4/Dtd/1/HorzSync"         "230" #"48"
    Option     "ALL/1/Port/4/Dtd/1/HorzSyncPulse"    "16" #"32"
    Option     "ALL/1/Port/4/Dtd/1/HorzBlank"        "476" #"160"
    Option     "ALL/1/Port/4/Dtd/1/VertActive"       "768"
    Option     "ALL/1/Port/4/Dtd/1/VertSync"         "4" #"3"
    Option     "ALL/1/Port/4/Dtd/1/VertSyncPulse"    "1" #"5"
    Option     "ALL/1/Port/4/Dtd/1/VertBlank"        "8" #"22"
    Option     "ALL/1/Port/4/Dtd/1/Flags"            "0x20000"
    Option     "ALL/1/Port/4/Attr/27"    "0"
    Option     "ALL/1/Port/4/Attr/26"    "24"
    Option     "ALL/1/Port/4/Attr/18"    "1"
    Option     "ALL/1/Port/4/Attr/60"    "1"
    Option     "PortDrivers" "lvds"
EndSection
Section "Screen"
        Identifier "Screen0"
        Device     "Card0"
        Monitor    "Monitor0"
        DefaultDepth  24
        SubSection "Display"
                Modes     "1366x768" "1280x1024" "1024x768" "800x600"
                Depth     24
        EndSubSection
EndSection
Section "DRI"
        Group 0
        Mode 0666
EndSection
Section "Extensions"
        Option  "Composite" "enable"
EndSection
Section "ServerFlags"
        Option "GlxVisuals" "all"
#       Option "IgnoreABI" "true"
        Option "AIGLX" "true"
        Option "DRM" "true"
        Option "Xinerama" "false"
EndSection
The Xorg.0.log :
[  6601.786]
X.Org X Server 1.9.0
Release Date: 2010-08-20
[  6601.786] X Protocol Version 11, Revision 0
[  6601.786] Build Operating System: Linux 2.6.24-29-server i686 Ubuntu
[  6601.786] Current Operating System: Linux one 3.5.0-21-generic #32-Ubuntu SMP Tue Dec 11 18:52:46 UTC 2012 i686
[  6601.786] Kernel command line: BOOT_IMAGE=/vmlinuz-3.5.0-21-generic root=/dev/mapper/ubuntu-root ro quiet acpi_backlight=vendor acpi_osi=Linux mem=896mb
[  6601.786] Build Date: 20 October 2011  03:03:54PM
[  6601.786] xorg-server 2:1.9.0-0ubuntu7.6 (For technical support please see http://www.ubuntu.com/support)
[  6601.786] Current version of pixman: 0.26.0
[  6601.786]    Before reporting problems, check http://wiki.x.org
        to make sure that you have the latest version.
[  6601.786] Markers: (--) probed, (**) from config file, (==) default setting,
        (++) from command line, (!!) notice, (II) informational,
        (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[  6601.787] (==) Log file: "/var/log/Xorg.0.log", Time: Tue Jan 22 13:29:34 2013
[  6601.787] (==) Using config file: "/etc/X11/xorg.conf"
[  6601.787] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[  6601.789] (==) ServerLayout "X.org Configured"
[  6601.789] (**) |-->Screen "Screen0" (0)
[  6601.789] (**) |   |-->Monitor "Monitor0"
[  6601.790] (**) |   |-->Device "Card0"
[  6601.790] (**) Option "Xinerama" "false"
[  6601.790] (**) Option "AIGLX" "true"
[  6601.790] (**) Option "GlxVisuals" "all"
[  6601.790] (==) Automatically adding devices
[  6601.790] (==) Automatically enabling devices
[  6601.790] (WW) `fonts.dir' not found (or not valid) in "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType".
[  6601.790]    Entry deleted from font path.
[  6601.790]    (Run 'mkfontdir' on "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType").
[  6601.791] (==) FontPath set to:
        /usr/share/fonts/X11/misc,
        /usr/share/fonts/X11/cyrillic,
        /usr/share/fonts/X11/100dpi/:unscaled,
        /usr/share/fonts/X11/75dpi/:unscaled,
        /usr/share/fonts/X11/Type1,
        /usr/share/fonts/X11/100dpi,
        /usr/share/fonts/X11/75dpi,
        built-ins
[  6601.791] (==) ModulePath set to "/usr/lib/xorg/extra-modules,/usr/lib/xorg/modules"
[  6601.791] (**) Extension "Composite" is enabled
[  6601.791] (II) The server relies on udev to provide the list of input devices.
        If no devices become available, reconfigure udev or disable AutoAddDevices.
[  6601.791] (II) Loader magic: 0x81f8e00
[  6601.791] (II) Module ABI versions:
[  6601.791]    X.Org ANSI C Emulation: 0.4
[  6601.791]    X.Org Video Driver: 8.0
[  6601.791]    X.Org XInput driver : 11.0
[  6601.791]    X.Org Server Extension : 4.0
[  6601.792] (--) PCI:*(0:0:2:0) 8086:8108:1025:0244 rev 7, Mem @ 0xb0080000/524288, 0xc0000000/268435456, 0xb0000000/262144, I/O @ 0x00001800/8
[  6601.793] (II) Open ACPI successful (/var/run/acpid.socket)
[  6601.793] (II) LoadModule: "extmod"
[  6601.794] (II) Loading /usr/lib/xorg/modules/extensions/libextmod.so
[  6601.795] (II) Module extmod: vendor="X.Org Foundation"
[  6601.795]    compiled for 1.9.0, module version = 1.0.0
[  6601.795]    Module class: X.Org Server Extension
[  6601.795]    ABI class: X.Org Server Extension, version 4.0
[  6601.795] (II) Loading extension MIT-SCREEN-SAVER
[  6601.795] (II) Loading extension XFree86-VidModeExtension
[  6601.795] (II) Loading extension XFree86-DGA
[  6601.795] (II) Loading extension DPMS
[  6601.795] (II) Loading extension XVideo
[  6601.795] (II) Loading extension XVideo-MotionCompensation
[  6601.795] (II) Loading extension X-Resource
[  6601.795] (II) LoadModule: "dbe"
[  6601.796] (II) Loading /usr/lib/xorg/modules/extensions/libdbe.so
[  6601.796] (II) Module dbe: vendor="X.Org Foundation"
[  6601.796]    compiled for 1.9.0, module version = 1.0.0
[  6601.797]    Module class: X.Org Server Extension
[  6601.797]    ABI class: X.Org Server Extension, version 4.0
[  6601.797] (II) Loading extension DOUBLE-BUFFER
[  6601.797] (II) LoadModule: "glx"
[  6601.797] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[  6601.798] (II) Module glx: vendor="X.Org Foundation"
[  6601.798]    compiled for 1.9.0, module version = 1.0.0
[  6601.798]    ABI class: X.Org Server Extension, version 4.0
[  6601.798] (**) AIGLX enabled
[  6601.798] (II) Loading extension GLX
[  6601.798] (II) LoadModule: "record"
[  6601.799] (II) Loading /usr/lib/xorg/modules/extensions/librecord.so
[  6601.799] (II) Module record: vendor="X.Org Foundation"
[  6601.799]    compiled for 1.9.0, module version = 1.13.0
[  6601.799]    Module class: X.Org Server Extension
[  6601.799]    ABI class: X.Org Server Extension, version 4.0
[  6601.799] (II) Loading extension RECORD
[  6601.799] (II) LoadModule: "dri"
[  6601.800] (II) Loading /usr/lib/xorg/modules/extensions/libdri.so
[  6601.800] (II) Module dri: vendor="X.Org Foundation"
[  6601.801]    compiled for 1.9.0, module version = 1.0.0
[  6601.801]    ABI class: X.Org Server Extension, version 4.0
[  6601.801] (II) Loading extension XFree86-DRI
[  6601.801] (II) LoadModule: "dri2"
[  6601.801] (II) Loading /usr/lib/xorg/modules/extensions/libdri2.so
[  6601.802] (II) Module dri2: vendor="X.Org Foundation"
[  6601.802]    compiled for 1.9.0, module version = 1.2.0
[  6601.802]    ABI class: X.Org Server Extension, version 4.0
[  6601.802] (II) Loading extension DRI2
[  6601.802] (II) LoadModule: "emgd"
[  6601.802] (II) Loading /usr/lib/xorg/modules/drivers/emgd_drv.so
[  6601.803] (II) Module emgd: vendor="Intel(R) Corporation"
[  6601.803]    compiled for 1.9.0, module version = 1.16.3196
[  6601.803]    Module class: X.Org Video Driver
[  6601.803]    ABI class: X.Org Video Driver, version 8.0
[  6601.803] (II) EMGD: Intel(R) Embedded Media and Graphics Driver version 1.16.3196 for:
        Intel US15W Class
[  6601.803] (++) using VT number 7
[  6601.804] (==) EMGD(0): RGB weight 888
[  6601.804] (==) EMGD(0): Default visual is TrueColor
[  6601.805] drmOpenDevice: node name is /dev/dri/card0
[  6601.805] drmOpenDevice: open result is 9, (OK)
[  6601.805] drmOpenByBusid: Searching for BusID PCI:00:00:00
[  6601.805] drmOpenByBusid: drmOpenMinor returns 9
[  6601.805] drmOpenByBusid: drmGetBusid reports pci:0000:00:02.0
[  6601.805] drmOpenDevice: node name is /dev/dri/card1
[  6601.812] drmOpenByBusid: drmOpenMinor returns -1
[  6601.812] drmOpenDevice: node name is /dev/dri/card2
[  6601.818] drmOpenByBusid: drmOpenMinor returns -1
[  6601.818] drmOpenDevice: node name is /dev/dri/card3
[  6601.825] drmOpenByBusid: drmOpenMinor returns -1
[  6601.825] drmOpenDevice: node name is /dev/dri/card4
[  6601.831] drmOpenByBusid: drmOpenMinor returns -1
[  6601.831] drmOpenDevice: node name is /dev/dri/card5
[  6601.838] drmOpenByBusid: drmOpenMinor returns -1
[  6601.838] drmOpenDevice: node name is /dev/dri/card6
[  6601.844] drmOpenByBusid: drmOpenMinor returns -1
[  6601.844] drmOpenDevice: node name is /dev/dri/card7
[  6601.850] drmOpenByBusid: drmOpenMinor returns -1
[  6601.851] drmOpenDevice: node name is /dev/dri/card8
[  6601.857] drmOpenByBusid: drmOpenMinor returns -1
[  6601.857] drmOpenDevice: node name is /dev/dri/card9
[  6601.864] drmOpenByBusid: drmOpenMinor returns -1
[  6601.864] drmOpenDevice: node name is /dev/dri/card10
[  6601.870] drmOpenByBusid: drmOpenMinor returns -1
[  6601.870] drmOpenDevice: node name is /dev/dri/card11
[  6601.876] drmOpenByBusid: drmOpenMinor returns -1
[  6601.876] drmOpenDevice: node name is /dev/dri/card12
[  6601.883] drmOpenByBusid: drmOpenMinor returns -1
[  6601.883] drmOpenDevice: node name is /dev/dri/card13
[  6601.889] drmOpenByBusid: drmOpenMinor returns -1
[  6601.890] drmOpenDevice: node name is /dev/dri/card14
[  6601.896] drmOpenByBusid: drmOpenMinor returns -1
[  6601.896] drmOpenDevice: node name is /dev/dri/card15
[  6601.903] drmOpenByBusid: drmOpenMinor returns -1
[  6601.903] drmOpenDevice: node name is /dev/dri/card0
[  6601.903] drmOpenDevice: open result is 9, (OK)
[  6601.903] drmGetBusid returned ''
[  6601.903] (II) EMGD(0): Chipset: "Intel SCH US15 Chipset"
[  6601.904] (II) EMGD(0): Detected kernel module from EMGD build 3196
[  6601.904] (II) EMGD(0): Checking for new style options
[  6601.904] (II) EMGD(0): Processing version 7.0 options
[  6601.904] (II) EMGD(0): Using configuration 1
[  6601.904] (II) EMGD(0): Checking for US15 specific configuration.
[  6601.904] (II) EMGD(0): Checking for non-chipset specific configuration.
[  6601.904] (II) EMGD(0): Setting port_order to 40000
[  6601.905] (II) EMGD(0): Setting Enable Reg Override
[  6601.905] (II) EMGD(0): Setting Disp Arb
[  6601.905] (II) EMGD(0): Allocated local dtd for port=3 dtdid=1
[  6601.905] (II) EMGD(0): Option processing done!
[  6602.146] (II) EMGD(0): Valid Display Configurations:
[  6602.146] (II) EMGD(0):   DC: 0x00000041
[  6602.147] (II) EMGD(0):   DC: 0x00000000
[  6602.147] (II) EMGD(0): Using Display Configuration 0x00000041
[  6602.147] (**) EMGD(0): Depth 24, (--) framebuffer bpp 32
[  6602.147] (==) EMGD(0): Using gamma correction (1.0, 1.0, 1.0)
[  6602.147] (II) EMGD(0): 1 modes passed validation checks
[  6602.147] (--) EMGD(0): Virtual size is 1366x768 (pitch 0)
[  6602.147] (**) EMGD(0): *Built-in mode "1366x768": 54.7 MHz (scaled from 0.0 MHz), 29.7 kHz, 38.0 Hz
[  6602.148] (II) EMGD(0): Modeline "1366x768"x38.0   54.72  1366 1595 1611 1841  768 771 772 775 (29.7 kHz)
[  6602.148] (==) EMGD(0): DPI set to (96, 96)
[  6602.148] (II) Loading sub module "fb"
[  6602.148] (II) LoadModule: "fb"
[  6602.149] (II) Loading /usr/lib/xorg/modules/libfb.so
[  6602.150] (II) Module fb: vendor="X.Org Foundation"
[  6602.150]    compiled for 1.9.0, module version = 1.0.0
[  6602.150]    ABI class: X.Org ANSI C Emulation, version 0.4
[  6602.150] (II) EMGD(0): Rotation, Flip * RenderScale options do not support XVideo, XVideo Disabled.
[  6602.150] (II) Loading sub module "ramdac"
[  6602.150] (II) LoadModule: "ramdac"
[  6602.150] (II) Module "ramdac" already built-in
[  6602.150] (II) Loading sub module "shadowfb"
[  6602.150] (II) LoadModule: "shadowfb"
[  6602.151] (II) Loading /usr/lib/xorg/modules/libshadowfb.so
[  6602.152] (II) Module shadowfb: vendor="X.Org Foundation"
[  6602.152]    compiled for 1.9.0, module version = 1.0.0
[  6602.152]    ABI class: X.Org ANSI C Emulation, version 0.4
[  6602.152] (II) EMGD(0): General Driver Configuration Options
[  6602.152] (II) EMGD(0):   PCF Version:            7.00
[  6602.152] (II) EMGD(0):   Configuration ID:       1
[  6602.152] (II) EMGD(0): Primary Display Configuration Options
[  6602.152] (II) EMGD(0):   VideoRam (Pixmap Cache): 32768
[  6602.152] (II) EMGD(0):   PORT AND DISPLAY OPTIONS
[  6602.153] (II) EMGD(0):     Port Order:           40000
[  6602.153] (II) EMGD(0):     Display Config:       Single
[  6602.153] (II) EMGD(0):     Display Detect:       On
[  6602.153] (II) EMGD(0):     FB Blend Overlay:     Off
[  6602.153] (II) EMGD(0):     Gang DVO:             Off
[  6602.153] (II) EMGD(0):     Refresh Rate:         60
[  6602.153] (II) EMGD(0):     Clone Width:          0
[  6602.153] (II) EMGD(0):     Clone Height:         0
[  6602.153] (II) EMGD(0):     Clone Refresh:        0
[  6602.153] (II) EMGD(0):   FRAMEBUFFER OPTIONS
[  6602.153] (II) EMGD(0):     Shadow FB:            On
[  6602.153] (II) EMGD(0):     Tear FB:              Off
[  6602.154] (II) EMGD(0):     Resize:               Off
[  6602.154] (II) EMGD(0):    GL TEXTURE STREAM OUTPUT:         Off
[  6602.154] (II) EMGD(0):   FRAMEBUFFER ORIENTATION OPTIONS
[  6602.154] (II) EMGD(0):     Rotation:             0 degrees
[  6602.154] (II) EMGD(0):     Flip:                 Off
[  6602.154] (II) EMGD(0):   HARDWARE ACCELERATION OPTIONS
[  6602.154] (II) EMGD(0):     HW 2D Accel:          On
[  6602.154] (II) EMGD(0):     HW Cursor:            On
[  6602.154] (II) EMGD(0):   XVIDEO OPTIONS
[  6602.154] (II) EMGD(0):     XVideo:               Off
[  6602.154] (II) EMGD(0):     XVideoBlend:          Off
[  6602.154] (II) EMGD(0):     XVideoMC:             Off
[  6602.155] (II) EMGD(0):     XVideoKey:            0xff00ff00
[  6602.155] (II) EMGD(0):     Overlay Gamma Red:    0x100
[  6602.155] (II) EMGD(0):     Overlay Gamma Green:  0x100
[  6602.155] (II) EMGD(0):     Overlay Gamma Blue:   0x100
[  6602.155] (II) EMGD(0):     Overlay Brightness:   0x8000
[  6602.155] (II) EMGD(0):     Overlay Contrast:     0x8000
[  6602.155] (II) EMGD(0):     Overlay Saturation:   0x8000
[  6602.155] (II) EMGD(0):     DRI:                  On
[  6602.155] (II) EMGD(0):     DRI2:                 On
[  6602.155] (II) EMGD(0):     EDID:                 On
[  6602.155] (II) EMGD(0):   QUICKBOOT OPTIONS
[  6602.155] (II) EMGD(0):     QuickBoot:            1
[  6602.156] (II) EMGD(0):     Seamless:             Off
[  6602.156] (II) EMGD(0):     Video Input:          0
[  6602.156] (II) EMGD(0):     Splash Screen:        Off
[  6602.156] (II) EMGD(0):     Freeze FB:        Off
[  6602.156] (II) EMGD(0):    INTERRUPT OPTIONS
[  6602.156] (II) EMGD(0):      Polling:             Off
[  6602.156] (II) EMGD(0):   GLOBAL PER PORT OPTIONS
[  6602.156] (II) EMGD(0):   Port 2            (null)
[  6602.156] (II) EMGD(0):      Multi-DVO:      Off
[  6602.156] (II) EMGD(0):      Rotation:       0 degrees
[  6602.156] (II) EMGD(0):      Flip:           Off
[  6602.157] (II) EMGD(0):      Centering:      Off
[  6602.157] (II) EMGD(0):      RenderScale:    Off
[  6602.157] (II) EMGD(0):      EDID:           Off
[  6602.157] (II) EMGD(0):      EDID Avail:     0x5
[  6602.157] (II) EMGD(0):      EDID Not Avail: 0x5
[  6602.157] (II) EMGD(0):      PANEL INFORMATION
[  6602.157] (II) EMGD(0):         FP width:     0
[  6602.157] (II) EMGD(0):         FP height:    0
[  6602.157] (II) EMGD(0):         BKLT Enable:  0
[  6602.157] (II) EMGD(0):         BKLT Method:  0
[  6602.157] (II) EMGD(0):         BKLT T1:      0
[  6602.157] (II) EMGD(0):         BKLT T2:      0
[  6602.157] (II) EMGD(0):         BKLT T3:      0
[  6602.158] (II) EMGD(0):         BKLT T4:      0
[  6602.158] (II) EMGD(0):         BKLT T5:      0
[  6602.158] (II) EMGD(0):         GPIO Pin VDD: 0
[  6602.158] (II) EMGD(0):         GPIO Pin VEE: 0
[  6602.158] (II) EMGD(0):         GPIO Pin BKLT:0
[  6602.158] (II) EMGD(0):         DVO i2c pin:  0
[  6602.158] (II) EMGD(0):         DVO i2c DAB:  0
[  6602.158] (II) EMGD(0):         DVO i2c speed:0
[  6602.158] (II) EMGD(0):         DVO ddc pin:  0
[  6602.158] (II) EMGD(0):         DVO ddc speed:0
[  6602.158] (II) EMGD(0):      Number DTD's:   0
[  6602.158] (II) EMGD(0):      Number Attr's:  0
[  6602.159] (II) EMGD(0):   Port 4            LVDS
[  6602.159] (II) EMGD(0):      Multi-DVO:      Off
[  6602.159] (II) EMGD(0):      Rotation:       0 degrees
[  6602.159] (II) EMGD(0):      Flip:           Off
[  6602.159] (II) EMGD(0):      Centering:      Off
[  6602.159] (II) EMGD(0):      RenderScale:    On
[  6602.159] (II) EMGD(0):      EDID:           Off
[  6602.159] (II) EMGD(0):      EDID Avail:     0x0
[  6602.159] (II) EMGD(0):      EDID Not Avail: 0x5
[  6602.159] (II) EMGD(0):      PANEL INFORMATION
[  6602.159] (II) EMGD(0):         FP width:     0
[  6602.159] (II) EMGD(0):         FP height:    0
[  6602.160] (II) EMGD(0):         BKLT Enable:  0
[  6602.160] (II) EMGD(0):         BKLT Method:  1
[  6602.160] (II) EMGD(0):         BKLT T1:      60
[  6602.160] (II) EMGD(0):         BKLT T2:      200
[  6602.160] (II) EMGD(0):         BKLT T3:      200
[  6602.160] (II) EMGD(0):         BKLT T4:      50
[  6602.160] (II) EMGD(0):         BKLT T5:      400
[  6602.160] (II) EMGD(0):         GPIO Pin VDD: 0
[  6602.160] (II) EMGD(0):         GPIO Pin VEE: 0
[  6602.160] (II) EMGD(0):         GPIO Pin BKLT:0
[  6602.160] (II) EMGD(0):         DVO i2c pin:  0
[  6602.160] (II) EMGD(0):         DVO i2c DAB:  0
[  6602.160] (II) EMGD(0):         DVO i2c speed:0
[  6602.160] (II) EMGD(0):         DVO ddc pin:  0
[  6602.161] (II) EMGD(0):         DVO ddc speed:0
[  6602.161] (II) EMGD(0):      Number DTD's:   1
[  6602.161] (II) EMGD(0):        1-width:       1366
[  6602.161] (II) EMGD(0):        1-height:      768
[  6602.161] (II) EMGD(0):        1-refresh:     0
[  6602.161] (II) EMGD(0):        1-dclk:        54720
[  6602.161] (II) EMGD(0):        1-horz total:  0
[  6602.161] (II) EMGD(0):        1-horz b_start:1365
[  6602.161] (II) EMGD(0):        1-horz b_end:  1841
[  6602.161] (II) EMGD(0):        1-horz s_start:1595
[  6602.161] (II) EMGD(0):        1-horz s_end:  1611
[  6602.161] (II) EMGD(0):        1-vert total:  0
[  6602.161] (II) EMGD(0):        1-vert b_start:767
[  6602.161] (II) EMGD(0):        1-vert b_end:  775
[  6602.161] (II) EMGD(0):        1-vert s_start:771
[  6602.161] (II) EMGD(0):        1-vert s_end:  772
[  6602.161] (II) EMGD(0):        1-flags:       0x20000
[  6602.161] (II) EMGD(0):      Number Attr's:  4
[  6602.161] (==) Depth 24 pixmap format is 32 bpp
[  6602.548] drmOpenDevice: node name is /dev/dri/card0
[  6602.548] drmOpenDevice: open result is 10, (OK)
[  6602.549] drmOpenByBusid: Searching for BusID PCI:00:02:00
[  6602.549] drmOpenDevice: node name is /dev/dri/card0
[  6602.549] drmOpenDevice: open result is 10, (OK)
[  6602.549] drmOpenByBusid: drmOpenMinor returns 10
[  6602.549] drmOpenByBusid: Interface 1.4 failed, trying 1.1
[  6602.550] drmOpenByBusid: drmGetBusid reports pci:0000:00:02.0
[  6602.550] drmOpenDevice: node name is /dev/dri/card0
[  6602.551] drmOpenDevice: open result is 10, (OK)
[  6602.551] drmOpenByBusid: Searching for BusID PCI:00:02:00
[  6602.551] drmOpenDevice: node name is /dev/dri/card0
[  6602.552] drmOpenByBusid: drmOpenMinor returns 10
[  6602.552] drmOpenByBusid: Interface 1.4 failed, trying 1.1
[  6602.552] drmOpenByBusid: drmGetBusid reports pci:0000:00:02.0
[  6602.553] drmOpenDevice: node name is /dev/dri/card0
[  6602.553] drmOpenDevice: open result is 10, (OK)
[  6602.553] drmOpenByBusid: Searching for BusID PCI:00:02:00
[  6602.553] drmOpenByBusid: drmOpenMinor returns 10
[  6602.553] drmOpenByBusid: Interface 1.4 failed, trying 1.1
[  6602.553] drmOpenByBusid: drmGetBusid reports pci:0000:00:02.0
[  6602.564] (II) EMGD(0): Rotation : 0 degrees
[  6602.564] (II) EMGD(0): RendScale: 0
[  6602.567] (II) EMGD(0): ShadowFB allocated
[  6602.630] drmOpenDevice: node name is /dev/dri/card0
[  6602.630] drmOpenDevice: open result is 11, (OK)
[  6602.630] drmOpenByBusid: Searching for BusID PCI:00:02:00
[  6602.630] drmOpenByBusid: drmOpenMinor returns 11
[  6602.630] drmOpenByBusid: Interface 1.4 failed, trying 1.1
[  6602.630] drmOpenByBusid: drmGetBusid reports pci:0000:00:02.0
[  6602.631] drmOpenByBusid: Interface 1.4 failed, trying 1.1
[  6602.631] drmOpenByBusid: drmGetBusid reports pci:0000:00:02.0
[  6602.631] drmOpenDevice: node name is /dev/dri/card0
[  6602.631] drmOpenDevice: open result is 11, (OK)
[  6602.631] drmOpenByBusid: Searching for BusID PCI:00:02:00
[  6602.631] drmOpenByBusid: drmOpenMinor returns 11
[  6602.636] (II) EMGD(0): [DRI2] Setup complete
[  6602.637] (II) EMGD(0): [DRI2]   DRI driver: emgd
[  6602.637] (II) EMGD(0): DRI2 initialization complete.
[  6602.637] (II) UXA(0): Driver registered support for the following operations:
[  6602.637] (II)         solid
[  6602.637] (II)         copy
[  6602.637] (II)         composite (RENDER acceleration)
[  6602.637] (II) EMGD(0): ShadowFB initialization complete
[  6602.637] (==) EMGD(0): Backing store disabled
[  6602.656] drmOpenDevice: node name is /dev/dri/card0
[  6602.656] drmOpenDevice: open result is 12, (OK)
[  6602.657] drmOpenByBusid: Searching for BusID PCI:00:02:00
[  6602.657] drmOpenDevice: node name is /dev/dri/card0
[  6602.657] drmOpenDevice: open result is 12, (OK)
[  6602.657] drmOpenByBusid: drmOpenMinor returns 12
[  6602.657] drmOpenByBusid: Interface 1.4 failed, trying 1.1
[  6602.657] drmOpenByBusid: drmGetBusid reports pci:0000:00:02.0
[  6602.658] drmOpenDevice: open result is 12, (OK)
[  6602.658] drmOpenByBusid: drmOpenMinor returns 12
[  6602.658] drmOpenByBusid: Interface 1.4 failed, trying 1.1
[  6602.658] drmOpenByBusid: drmGetBusid reports pci:0000:00:02.0
[  6602.659] (II) EMGD(0): Rotation : 0 degrees
[  6602.659] (II) EMGD(0): RendScale: 0
[  6602.664] (II) EMGD(0): ShadowFB allocated
[  6602.671] (II) EMGD(0): Hardware Cursor Initialization complete.
[  6602.671] (==) EMGD(0): Silken mouse enabled
[  6602.671] (==) EMGD(0): DPMS enabled
[  6602.672] (==) RandR enabled
[  6602.673] (II) Initializing built-in extension Generic Event Extension
[  6602.673] (II) Initializing built-in extension SHAPE
[  6602.673] (II) Initializing built-in extension MIT-SHM
[  6602.673] (II) Initializing built-in extension XInputExtension
[  6602.673] (II) Initializing built-in extension XTEST
[  6602.673] (II) Initializing built-in extension BIG-REQUESTS
[  6602.673] (II) Initializing built-in extension SYNC
[  6602.673] (II) Initializing built-in extension XKEYBOARD
[  6602.673] (II) Initializing built-in extension XC-MISC
[  6602.673] (II) Initializing built-in extension SECURITY
[  6602.673] (II) Initializing built-in extension XINERAMA
[  6602.673] (II) Initializing built-in extension XFIXES
[  6602.673] (II) Initializing built-in extension RENDER
[  6602.673] (II) Initializing built-in extension RANDR
[  6602.673] (II) Initializing built-in extension COMPOSITE
[  6602.673] (II) Initializing built-in extension DAMAGE
[  6602.673] (II) Initializing built-in extension GESTURE
[  6602.719] drmOpenDevice: node name is /dev/dri/card0
[  6602.719] drmOpenDevice: open result is 12, (OK)
[  6602.719] drmOpenByBusid: Searching for BusID PCI:00:02:00
[  6602.719] drmOpenByBusid: drmOpenMinor returns 12
[  6602.719] drmOpenByBusid: Interface 1.4 failed, trying 1.1
[  6602.719] drmOpenByBusid: drmGetBusid reports pci:0000:00:02.0
[  6602.720] drmOpenDevice: open result is 12, (OK)
[  6602.720] drmOpenByBusid: Searching for BusID PCI:00:02:00
[  6602.720] drmOpenDevice: node name is /dev/dri/card0
[  6602.720] drmOpenByBusid: drmOpenMinor returns 12
[  6602.720] drmOpenByBusid: Interface 1.4 failed, trying 1.1
[  6602.720] drmOpenByBusid: drmGetBusid reports pci:0000:00:02.0
[  6602.721] drmOpenDevice: open result is 12, (OK)
[  6602.721] drmOpenByBusid: Searching for BusID PCI:00:02:00
[  6602.721] drmOpenDevice: node name is /dev/dri/card0
[  6602.721] drmOpenByBusid: drmOpenMinor returns 12
[  6602.721] drmOpenByBusid: Interface 1.4 failed, trying 1.1
[  6602.721] drmOpenByBusid: drmGetBusid reports pci:0000:00:02.0
[  6602.732] drmOpenDevice: node name is /dev/dri/card0
[  6602.732] drmOpenDevice: open result is 13, (OK)
[  6602.732] drmOpenByBusid: Searching for BusID PCI:00:02:00
[  6602.732] drmOpenByBusid: drmOpenMinor returns 13
[  6602.733] drmOpenByBusid: Interface 1.4 failed, trying 1.1
[  6602.733] drmOpenByBusid: drmGetBusid reports pci:0000:00:02.0
[  6602.733] drmOpenDevice: node name is /dev/dri/card0
[  6602.733] drmOpenDevice: open result is 13, (OK)
[  6602.733] drmOpenByBusid: Searching for BusID PCI:00:02:00
[  6602.733] drmOpenByBusid: drmOpenMinor returns 13
[  6602.734] drmOpenByBusid: drmOpenMinor returns 13
[  6602.734] drmOpenByBusid: Interface 1.4 failed, trying 1.1
[  6602.734] drmOpenByBusid: drmGetBusid reports pci:0000:00:02.0
[  6602.750] (II) AIGLX: enabled GLX_MESA_copy_sub_buffer
[  6602.750] (II) AIGLX: enabled GLX_INTEL_swap_event
[  6602.750] (II) AIGLX: enabled GLX_SGI_make_current_read
[  6602.750] (II) AIGLX: GLX_EXT_texture_from_pixmap backed by buffer objects
[  6602.750] (II) AIGLX: Loaded and initialized /usr/lib/dri/emgd_dri.so
[  6602.750] (II) GLX: Initialized DRI2 GL provider for screen 0
[  6602.850] (II) XKB: reuse xkmfile /var/lib/xkb/server-B20D7FC79C7F597315E3E501AEF10E0D866E8E92.xkm
[  6602.892] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[  6602.892] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[  6602.893] (II) LoadModule: "evdev"
[  6602.893] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[  6602.894] (II) Module evdev: vendor="X.Org Foundation"
[  6602.894]    compiled for 1.9.0, module version = 2.3.2
[  6602.894]    Module class: X.Org XInput Driver
[  6602.894]    ABI class: X.Org XInput driver, version 11.0
[  6602.894] (**) Power Button: always reports core events
[  6602.894] (**) Power Button: Device: "/dev/input/event1"
[  6602.894] (II) Power Button: Found keys
[  6602.894] (II) Power Button: Configuring as keyboard
[  6602.894] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD)
[  6602.895] (**) Option "xkb_rules" "evdev"
[  6602.895] (**) Option "xkb_model" "evdev"
[  6602.895] (**) Option "xkb_layout" "us"
[  6602.903] (II) XKB: reuse xkmfile /var/lib/xkb/server-D378AD8F86E560F712A83EE36E4E5E92C595B9BD.xkm
[  6602.906] (II) config/udev: Adding input device Lid Switch (/dev/input/event0)
[  6602.906] (II) No input driver/identifier specified (ignoring)
[  6602.907] (II) config/udev: Adding input device Sleep Button (/dev/input/event2)
[  6602.907] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[  6602.907] (**) Sleep Button: always reports core events
[  6602.907] (**) Sleep Button: Device: "/dev/input/event2"
[  6602.907] (II) Sleep Button: Found keys
[  6602.907] (II) Sleep Button: Configuring as keyboard
[  6602.907] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD)
[  6602.907] (**) Option "xkb_rules" "evdev"
[  6602.908] (**) Option "xkb_model" "evdev"
[  6602.908] (**) Option "xkb_layout" "us"
[  6602.911] (II) config/udev: Adding input device HDA Intel MID Mic (/dev/input/event5)
[  6602.911] (II) No input driver/identifier specified (ignoring)
[  6602.912] (II) config/udev: Adding input device HDA Intel MID Headphone (/dev/input/event6)
[  6602.912] (II) No input driver/identifier specified (ignoring)
[  6602.919] (II) config/udev: Adding input device WebCam (/dev/input/event4)
[  6602.920] (**) WebCam: Applying InputClass "evdev keyboard catchall"
[  6602.920] (**) WebCam: always reports core events
[  6602.920] (**) WebCam: Device: "/dev/input/event4"
[  6602.920] (II) WebCam: Found keys
[  6602.920] (II) WebCam: Configuring as keyboard
[  6602.920] (II) XINPUT: Adding extended input device "WebCam" (type: KEYBOARD)
[  6602.920] (**) Option "xkb_rules" "evdev"
[  6602.920] (**) Option "xkb_model" "evdev"
[  6602.920] (**) Option "xkb_layout" "us"
[  6602.929] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event3)
[  6602.929] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[  6602.929] (**) AT Translated Set 2 keyboard: always reports core events
[  6602.929] (**) AT Translated Set 2 keyboard: Device: "/dev/input/event3"
[  6602.929] (II) AT Translated Set 2 keyboard: Found keys
[  6602.929] (II) AT Translated Set 2 keyboard: Configuring as keyboard
[  6602.929] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD)
[  6602.930] (**) Option "xkb_rules" "evdev"
[  6602.930] (**) Option "xkb_model" "evdev"
[  6602.930] (**) Option "xkb_layout" "us"
[  6602.932] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/event7)
[  6602.932] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "evdev touchpad catchall"
[  6602.932] (**) SynPS/2 Synaptics TouchPad: always reports core events
[  6602.932] (**) SynPS/2 Synaptics TouchPad: Device: "/dev/input/event7"
[  6602.932] (II) SynPS/2 Synaptics TouchPad: Found 3 mouse buttons
[  6602.932] (II) SynPS/2 Synaptics TouchPad: Found absolute axes
[  6602.933] (II) SynPS/2 Synaptics TouchPad: Found x and y absolute axes
[  6602.933] (II) SynPS/2 Synaptics TouchPad: Found absolute touchpad.
[  6602.933] (II) SynPS/2 Synaptics TouchPad: Configuring as touchpad
[  6602.933] (**) SynPS/2 Synaptics TouchPad: YAxisMapping: buttons 4 and 5
[  6602.933] (**) SynPS/2 Synaptics TouchPad: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[  6602.933] (II) XINPUT: Adding extended input device "SynPS/2 Synaptics TouchPad" (type: TOUCHPAD)
[  6602.933] (II) SynPS/2 Synaptics TouchPad: initialized for absolute axes.
[  6602.934] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/mouse0)
[  6602.934] (II) No input driver/identifier specified (ignoring)
A lsmod :
# lsmod
Module                  Size  Used by
joydev                 17161  0
i2c_isch               12639  0
arc4                   12473  2
snd_hda_codec_realtek    63493  1
snd_hda_intel          32515  0
coretemp               13168  0
snd_hda_codec         111547  2 snd_hda_codec_realtek,snd_hda_intel
snd_hwdep              13272  1 snd_hda_codec
uvcvideo               71277  0
videobuf2_core         32070  1 uvcvideo
videodev               95841  2 uvcvideo,videobuf2_core
videobuf2_vmalloc      12756  1 uvcvideo
videobuf2_memops       13184  1 videobuf2_vmalloc
kvm                   357806  0
snd_pcm                80163  2 snd_hda_intel,snd_hda_codec
microcode              18209  0
snd_seq_midi           13132  0
snd_rawmidi            25382  1 snd_seq_midi
psmouse                84843  0
snd_seq_midi_event     14475  1 snd_seq_midi
serio_raw              13031  0
snd_seq                51255  2 snd_seq_midi,snd_seq_midi_event
rfcomm                 37276  0
bnep                   17707  2
parport_pc             31968  0
bluetooth             183228  10 rfcomm,bnep
ppdev                  12817  0
snd_timer              24411  2 snd_pcm,snd_seq
snd_seq_device         14137  3 snd_seq_midi,snd_rawmidi,snd_seq
mac_hid                13037  0
ath5k                 135205  0
ath                    19187  1 ath5k
emgd                  577343  5
snd                    61991  9 snd_hda_codec_realtek,snd_hda_intel,snd_hda_codec,snd_hwdep,snd_pcm,snd_rawmidi,snd_seq,snd_timer,snd_seq_device
mac80211              461161  1 ath5k
lpc_sch                12727  0
cfg80211              175375  3 ath5k,ath,mac80211
ext2                   67204  1
soundcore              14599  1 snd
snd_page_alloc         14036  2 snd_hda_intel,snd_pcm
drm_kms_helper         47303  1 emgd
drm                   238768  7 emgd,drm_kms_helper
lp                     13299  0
parport                40753  3 parport_pc,ppdev,lp
xts                    12723  2
gf128mul               14503  1 xts
dm_crypt               22402  1
vesafb                 13477  1
pata_sch               12700  2
r8169                  55976  0
wmi                    18590  0
video                  18847  0
My modules blacklisted :
blacklist gma500_gfx
blacklist psb_gfx
blacklist acer_wmi
My Grub important informations
GRUB_GFXPAYLOAD_LINUX=1366x768x24
GRUB_CMDLINE_LINUX_DEFAULT="quiet acpi_backlight=vendor acpi_osi=Linux console=tty1 mem=896mb"
My packages
ii  x11-xserver-utils                         7.7~3ubuntu1                              i386         X server utilities
ii  xserver-common                            2:1.13.0-0ubuntu6.1                       all          common files used by various X servers
ii  xserver-xephyr                            2:1.13.0-0ubuntu6.1                       i386         nested X server
ii  xserver-xorg                              1:7.5+6ubuntu3.1                          i386         the X.Org X server
ii  xserver-xorg-core                         2:1.9.0-0ubuntu7.6                        i386         Xorg X server - core server
ii  xserver-xorg-input-evdev                  1:2.3.2-6ubuntu3.1                        i386         X.Org X server -- evdev input driver
ii  xserver-xorg-input-wacom                  1:0.10.8-0ubuntu1.1                       i386         X.Org X server -- Wacom input driver
ii  xserver-xorg-video-geode                  2.11.11-1~maverick1                       i386         X.Org X server -- Geode GX2/LX display driver
rc  xserver-xorg-video-intel                  2:2.20.9-0ubuntu2                         i386         X.Org X server -- Intel i8xx, i9xx display driver
rc  xserver-xorg-video-openchrome             1:0.3.1-0ubuntu1                          i386         X.Org X server -- VIA display driver
ii  xserver-xorg-video-savage                 1:2.3.1-2ubuntu2.1                        i386         X.Org X server -- Savage display driver
rc  xserver-xorg-video-vmware                 1:12.0.2+git.e5ac80d8-0ubuntu1            i386         X.Org X server -- VMware display driver
rc  libgl1-mesa-dri:i386                      9.0-0ubuntu1                              i386         free implementation of the OpenGL API -- DRI modules
ii  libgl1-mesa-glx:i386                      9.0-0ubuntu1                              i386         free implementation of the OpenGL API -- GLX runtime
ii  libglapi-mesa:i386                        9.0-0ubuntu1                              i386         free implementation of the GL API -- shared library
ii  libglu1-mesa:i386                         9.0.0-0ubuntu1                            i386         Mesa OpenGL utility library (GLU)
ii  libtxc-dxtn-s2tc0:i386                    0~git20110809-3                           i386         Texture compression library for Mesa
ii  mesa-utils                                8.0.1+git20110129+d8f7d6b-0ubuntu2        i386         Miscellaneous Mesa GL utilities
ii  emgd-bin                                  1.16.3196                                 i386         X11 drivers for Intel E6xx Processor and US15W/US15WP/WPT chipsets.
ii  emgd-dkms                                 1.16.3196                                 all          Intel EMGD driver in DKMS format.
My kernel is 3.5.0-21-generic from Ubuntu Quantal.
I hope someone could help me ! This will be very very very appreciated ! :D
mnstri
Post by mnstri »
Denis wrote:Hi,
This is not working anymore. Any other workaround?
mnstri
Post by mnstri »
Return to “Linux Mint”
