fit-PC3 Specifications
fit-PC3 specifications updated 17-Jan-2012.
See http://www.fit-pc.com/fit-pc3/docs/fit- ... ations.pdf
Updated:
- DDR3 frequency
- DisplayPort max resolution
- Removed reference to mSATA
- Removed reference to IR
- FACE Module interfaces
- Updated input voltage range
- Added power range for fit-PC3 Value
fit-PC3 specifications updated 18-Nov-2011.
Updated:
- HDMI in fit-PC3 Pro
- FACE module interfaces
- Added BT
anttonij
Re: fit-PC3 Specifications
Post by anttonij »
Any information about the weight of the Fit-PC3?
There are many configurations - each with a different weight. Average weight is in the ballpark of 800g.
cbratli
Post by cbratli »
Hi, what about auto-on, is that enabled as default?
Yes, auto-on is enabled.
tiborg
Post by tiborg »
Dear irads,
1. the new, 3. gen. fit pc is fanless also previous series? (so haven't moving part?)
2. With hd 6320 radeon works 2 HD monitor (so 2x 1920x1080) at the same time?
3. The video and 7.1 audio work in hdmi cable, or only video as fitpc2 (and other audio cable necessary)?
4. The OnLive works fine in fullscreen hd 1920x1080? (fitpc2, 2gh, 2gb, very slow, not available, only in smaller size) http://www.onlive.com/support/performance
5. The best fit-pc3 better than hybridbox?
(Intel Atom N330 CPU (2Ghz), Dual‐Core, Hyper‐Threading, Nvidia ION, GeForce® 9400 GPU, DirectX 10) http://hybridbox.tv/en/images/stories/h ... x_spec.pdf
So the hybridbox software works fine on new fitpc3?
6. the flash and html5 hd video playback fine in fullscreen (1920x180)? (youtube, some webvideo)
thank you
Yes, it is fanless.
2 HD monitors work with all models.
Yes. Audio on HDMI is supported.
I don't know. Check if working on AMD E450 - fit-PC3 Pro is identical.
Check benchmarks comparing N330+ION to AMD E450. I believe you will find performance of the latter are higher.
6. the flash and html5 hd video playback fine in fullscreen (1920x1080)? (youtube, some webvideo)
Haven't checked HTML5 video. Full-HD Flash plays well.
prpixel
Post by prpixel »
The passmark CPU score on the Atom 330 is 635. The Passmark CPU AMD G-T56N is 728. The Hybrid Box is fan cooled and draws twice the power of the Fit PC3 under load. According to the specs, one of those Hybrid Boxes is twice the size of the Fit PC3. The beauty of the Fit PC is the size and that it's passively cooled.
YMMV.
Are you sure about the Atom 330 numbers?
http://www.cpubenchmark.net/cpu_lookup. ... 40+1.60GHz
prpixel
Post by prpixel »
Got them from this site.
http://www.cpubenchmark.net/cpu.php?cpu ... 40+1.60GHz
Not sure if it's paired with the Ion chipset.
Sorry, looked up the wrong CPU. Posts have been corrected.
Return to “fit-PC3 hardware”
