Fit-PC2 with Windows Server 2003 R2 SP2?
jeremys
Post by jeremys »
Dear Board.
I must say this is one fancy HW for HomeServer for multiple usage.
? Are there Windows Server 2003 SP2 Drivers for ALL HW components?
? What about Windows Server 2008?
Yes, I've read the other posts and some minor problems with GFX drivers...
IR?
jeremys
Re: Fit-PC2 with Windows Server 2003 R2 SP2?
Post by jeremys »
One other thing: Bios is able to boot from USB devices such as DVD-drives and ThumbSticks..
? Can USB thumbastick to used as primary installation place for OS, eg can I install winServer2003 to USB stick? how dumb is the MS installer?
jeremys
Post by jeremys »
Well, there it is, server 2003 R2 SP2 system residing in 8GB CF-SSD.
performance is poor because CF (133x) isn't too fast even with UDMA4.
RamDisk increases it a lot! Remember to change /temp references to here!
GFX drivers had to install as SVGA adapter driver update via "I'll give you the location" dialogs, where you really give location.. Drivers are at LPCO/ root in the xp-driver package.
is this correct way to install GMA500 drivers? At least Display properties says GMA500 acceleration but there is no "controll panel"..
EDIT: Enable acceleration in troubleshoot displayproperties.
Still I remember to see 2 PCI-Devices without drivers in DeviceManager.. after aLL chipset drivers, lan etc....
what are those? :ugeek:
EDIT: 2 unknown PCI device problem is solved in some thread here.
steelmm
Post by steelmm »
Hi Guys
Just to let you know I have managed too install server 2008 and full display drivers and wifi and ethernet for vista 32bit under the this link h[url]ttp://www.umpcportal.com/modules/newbb/viewto ... 1254977979[/url]
The Drivers for this system works for server 2008.
I have no problem with my windows seerver 2008 as a web and fileserver too my network
Excellent
Cheers
steelmm :P
