fitlet2 serial port naming for centos 7
liorK
Post by liorK »
do you have a solution to activate fitlet2 serial com port on centos 7 ?
Andrey.Mazlin
Re: fitlet2 serial port naming for centos 7
Post by Andrey.Mazlin »
liorK wrote:
Thu May 21, 2020 12:18 pm
Did you try this?
Let's open up our text editor: nano /etc/sysconfig/grub.
Find the line labeled GRUB_CMDLINE_LINUX and add console=ttyS0 to the end (this assumes your serial port is ttyS0). ...
Save the file and exit.
Run
stty -F /dev/ttyS0 speed 9600
Then
grub2-mkconfig -o /boot/grub2/grub.cfg
Finally
systemctl start getty@ttyS0
Sincerely Yours,
Andrey Mazlin
Application Support Engineer
Useful links:
https://fit-iot.com/web/
Support Forum: https://fit-iot.com/forum/index.php
