I have an issue with the fit-pc2i 2GB/1.6 GHz Diskless - which is not starting up.Only power LED is lit.Anyone can share some troubleshooting info?
Umesh
fit-PC 2i Not starting up
Re: fit-PC 2i Not starting up
It is worth trying to follow the troubleshooting guide:
http://fit-pc.com/wiki/index.php/Fit-PC ... leshooting
Additionally, if the power LED is lit, perhaps it a case where there's no display output?
Are there more LED indicators, such as Numlock on the keyboard when the PC is on ?
Check the monitor setup including cable, also worth checking another RAM stick.
Thank you very much for the reply.There is no display when connected to monitor.Only power LED is lit.
The link provided didn't help.Is there anything else / other ways we can check further?
Thank you very much in advance.
Look forward to the reply.
- fitpc Image.jpeg (59.59 KiB) Viewed 14477 times
What about these?
"Are there more LED indicators, such as Numlock on the keyboard when the PC is on ?
Check the monitor setup including cable, also worth checking another RAM "stick.
Did you try another RAM module ?
Does the Numlock respond when you click it when the machine is on?
