Watchdog timer ?
Watchdog timer ?
I have recently managed to update the BIOS on a fit-PC2 , and I now have the Watchdog timer as an option in the BIOS setup. If I enable the timer, it appears to be operating - because the machine gets a hard reset, probably at 251 seconds, and reboots. I have attempted to install the software for Windows XP, including driver, and registry settings. However, the Watchdog Application falls over before getting to command prompt. Anyone else tried this ? Thanks.
Re: Watchdog timer ?
Is the problem that fit-PC2 takes more than 251 seconds to reach a state in WinXP where the application to reload the watchdog timer can be activated?
Not so far. The problem is that the XP Watchdog Timer code fails at launch with an error. It doesn't get to command mode.
Please specify the error and we will forward to our SW engineers.
For reference, these are the fit-PC2/XP watchdog instructions
http://www.fit-pc.com/wiki/index.php/Wa ... Windows_XP
Does anyone know how to save a Windows XP error Log to file ?
Screen shot attached of the System services log, showing repeated faults on trying to launch the Watchdog Application. Very brief summary of one of the faults. Not sure this will be enough for your software people?
Does the Watchdog application need to be installed anywhere special, with special privileges ?
Thank you for your help...........
- watchdogfault.JPG (219.75 KiB) Viewed 14610 times
