[SOLVED] No sound is coming out "line-out" [Linux Mint 18.1]
oss117
Post by oss117 »
I have installed Linux Mint 18.1 Serena on my MintBox2.
Everything works as expected except the audio output.
I followed all the instructions listed on the link :
https://help.ubuntu.com/community/SoundTroubleshooting
$ pacmd
Welcome to PulseAudio 8.0! Use "help" for usage information.
>>> list-sinks
1 sink(s) available.
  * index: 6
	driver: <module-alsa-card.c>
$ sudo aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: ALC888 Analog [ALC888 Analog]
  Subdevices: 1/1
  Subdevice #0: subdevice #0
card 0: PCH [HDA Intel PCH], device 1: ALC888 Digital [ALC888 Digital]
  Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 3: HDMI 0 [HDMI 0]
  Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 7: HDMI 1 [HDMI 1]
  Subdevices: 1/1
$ lspci -v | grep -A7 -i "audio"
00:1b.0 Audio device: Intel Corporation 7 Series/C210 Series Chipset Family High Definition Audio Controller (rev 04)
	Subsystem: Intel Corporation 7 Series/C210 Series Chipset Family High Definition Audio Controller
	Flags: bus master, fast devsel, latency 0, IRQ 33
	Memory at e0730000 (64-bit, non-prefetchable) [size=16K]
	Capabilities: <access denied>
	Kernel driver in use: snd_hda_intel
	Kernel modules: snd_hda_intel
00:1c.0 PCI bridge: Intel Corporation 7 Series/C210 Series Chipset Family PCI Express Root Port 1 (rev c4) (prog-if 00 [Normal decode])
Everything looks fine, except that no sound comes out the speakers.
Please note that I plugged the speakers to the correct slot, according to the user guide : "Line-out S/PDIF out" (see page 4 of the user guide).
Any suggestion ?
Best regards,
Denis
oss117
Re: No sound is coming out "line-out" [Linux Mint 18.1 Seren
Post by oss117 »
I was wondering : does the sound output behave like the video output, regarding the state of the connected device at boot time ?
If the video output is not connected, or if the connected display is not powered, at boot time, then the output is deactivated.
I'll try to boot the MintBox with the speakers powered and connected at boot time.
Best regards,
Denis
oss117
Post by oss117 »
I tried to boot while the speakers were connected and powered.
It does not change the fact that no sound comes out the speakers.
I can tell, however, that the audio electronic should be powered up.
Any idea ?
Denis
oss117
Post by oss117 »
I finally found out what was wrong. The information that comes from the printed manual chipped with my MintBox2 is wrong. The audio input and the audio output are swapped.
I downloaded the user guide shipped with my MintBox.
And this the equivalent information from the Intense PC Wiki :
You can see that the information on the user guide is wrong.
Best regards,
Denis
The scan of the user guide shipped with my MintBox2.
Return to “Linux Mint”
