Battery Annuciator in Linux 17.3 Cinnamon Panel
Generally, the right-hand corner of the bottom panel looks like this:
Normal Panel.png (5.55 KiB) Viewed 15932 times
But occasionally, this area includes a battery annunciator. When I hover over the battery, a "Using Battery Power" tag appears. It is as if Linux thinks Airtop is a laptop. A reboot generally clears the battery icon.
Abnormal Panel.png (6.26 KiB) Viewed 15932 times
Has anyone else experienced this?
Sussol
Re: Battery Annuciator in Linux 17.3 Cinnamon Panel
Post by Sussol »
Yes, we have experienced this with µSVRs operating under Windows (7 - 10) almost all of the time.
This has made me wonder if it is at all possible to have the advanced power management features of a laptop. I've done some research with Uncle Google about power management at the hardware level, and this has revealed surprisingly little. I appears that there must be some setting in a PCs Power Management Unit that lets the system know that there is a battery that can be managed. Why do the Airtop and µSVR have this (sometimes)? I hope somebody at Compulab can fill us in...
Thanks, Mark.
This Linux is a general OS distro.
Airtop and uSVR doesn't have any battery. Just ignore that.
ipc14
Post by ipc14 »
Just remove it. Right click on it and select "Remove Power Applet" or similar.
