Monitors or T.V.s - Used or tried by customers
RAM modules, mSATA and other devices compatible with fitlet
Arwen
Post by Arwen »
End-users,
Feel free to reply with information on your video monitors or T.V., known to work or
not. Please specify which fitlet model, and enough details about your monitor or T.V.
for someone else to purchase.
If you have multiple resolutions and refresh rates tested, please add.
Below is a template
Here is the monitor I have used successfully;
My fitlet model - MY_MODEL
Vendor - VENDOR NAME
Model - PART NUMBER
Type - (Monitor or T.V.)
Size - (Diagonal size in inches or centimeters)
Resolution(s) - (Horizantal and vertical)
Refresh rate(s) - (If relevant)
Interface - (Direct HDMI or used special adapter like HDMI to VGA)
Arwen Evenstar
Rivendale, Middle Earth
Arwen
Re: Monitors or T.V.s - Used or tried by customers
Post by Arwen »
The following thread shows that vendor rep Irad Stavi has tested a fitlet with
2560x1440 resolution, and can confirm it works.
http://www.fit-pc.com/forum/viewtopic.php?f=145&t=5550
Arwen Evenstar
ausppc
Re: Moinitors or T.V.s - Used or tried by customers
Post by ausppc »
Good news re: higher resolution output. :)
I've noticed that the MintBox Mini and fitlet-i default to some overscan setting when outputing hdmi to my Samsung SyncMaster 2494hs (1920x1080). This display has 1x hdmi, 1x dvi & 1x vga. Due to this overscan effect, the menu running across the top of the display and the start menu, task selector & etc aren't visible. When using the hdmi -> dvi cable the display appears as expected. I haven't tested hdmi -> vga as I don't have that kind of adaptor.
I mentioned this to a friend and he showed me how overscan and underscan can be adjusted on OS X but I've never seen an equivalent on Linux Mint.
For overscan - underscan adjsutment, have you tried the Catalyst Control Center?
Catalyst Control Center.png (89.61 KiB) Viewed 17749 times
bradjj
Post by bradjj »
Here are two monitors I have used successfully;
My fitlet model - MintBox Mini
Vendor - TCL
Model - L40D2700F
Type - TV (FHD)
Size - 40" (101cm)
Resolution - 1920 X 1080
Refresh rate - 60Hz
Interface - HDMI for both video and sound
Notes - Need to use 'Panorama' Zoom mode for correct display
My fitlet models - MintBox Mini and Fitlet B
Vendor - Soniq
Model - E32W13A
Type - TV (HD)
Size - 32" (80cm)
Resolution(s) - 1366 X 768
Refresh rate - 60Hz (from memory I think 60Hz)
Notes - Used this till it stopped working and then bought the TCL above
Return to “fitlet compatible devices”
