ethernet not working
We have several units that the ethernet ports only work intermittently. Any suggestions on how to get them to work all the time?
Re: ethernet not working
What do you mean work intermittently?
What do you mean several units? If so, probably some SW mismatch.
Please try re-install the drivers of the relevant Ethernet controllers.
The ethernet ports seem to randomly appear and disappear in the device manager. We have had 5 units demonstrating this behavior. We have reinstalled the appropriate drivers and got the same behavior.
Please reply what is the HW revision of fit-PC2 you experience the problems with? Which Ethernet controller is on board?
Older revisions use RTL8111C device, while newer use RTL8111F.
I've attached a pic of the ethernet ports listed through terminal. It does not specify if the device is RTL8111F or RTL8111C. I assume rev 7 is the revision number.
- 2013-10-22_11-23-11_44.jpg (1.77 MiB) Viewed 11464 times
Do you use Linux or Windows?
You're saying device manager but the capture is Linux terminal.
Please specify the exact OS.
