FIT PC 3 and GPS
lloydtum
FIT PC 3 and GPS
Post by lloydtum »
It seems that the FIT PC3 is too noisy for a GPS antenna. Any remedy on this?
I have FIT PC3 ribbed case and the GPS should be not more than 6" away from the PC.
Thank you, I hope someone could help me on this.
Thank you.
Re: FIT PC 3 and GPS
Fit-PC3 was not tested with GPS antenna. We will do some tests and I will provide you with the results. Thank you for submitting this unordinary issue
Update:
The only solution, is to isolate the Fit-PC3 from GPS antenna, with some sort of Faraday shield.
Return to “fit-PC3 hardware”
