VGA (or lack thereof)
evaguy
Post by evaguy »
I see in the specifications that the fit-PC3 has HDMI and Displayport, but no mention of VGA. Is it possible to use a Displayport to VGA adapter? If so, is 800x600 a possible resolution? My special application requires that specific resolution. Thanks! :D
Re: VGA (or lack thereof)
You can use FitPC3 with a FitVGA adapter under Windows 7 environment
Takenaka
Post by Takenaka »
Where can I get the FitVGA adapter for VGA monitor? Thanks.
prpixel
Post by prpixel »
Amazon.com
Please contact sales@compulab.co.il
Andy
Post by Andy »
Hi there,
fit-PC 3 comes with an HDMI to DVI adaptor, so is it not possible to just extend the supplied adaptor with a DVI to VGA adaptor such as the one shown in the attatched image?
HDMI --> DVI --> VGA
DVI to VGA.jpg (20.93 KiB) Viewed 22229 times
From this picture I can't tell if will suite or not. The adapter should convert a digital (HDMI/DVI) to an analog (VGA) signal. If this is only a mechanical adapter, then it will not work.
ilia
Post by ilia »
Our customer wants to connect the Fit-PC3 video to the KVM switch they have.
Unfortunately, this switch supports only the VGA(analog) video input from the PC - not any kind of digital input the Fit-PC3 provides.
Can you suggest some solution for this?
I.e. some digital to analog conversion dongle which can provide the VGA signal to the switch?
The mentioned Fit-PC3 runs Linux - the stock Linux Mint witch is came with the product. If the stock Linux driver does not supports such a setup, can you advice of the needed tweakings?
Thanks.
Ilia.
You can consider to buy one of those DP adapters. They are suitable with Fit-PC3 .
Return to “Display interface”
