How do I Clone one fit-PC2 to another
Mongo
Post by Mongo »
I have about 80 of these devices that I need to image from one that I have completely setup (Ubuntu 9.10 OS, w/8Gb SD).
What is the easiest way to go about copying or cloning the memory card?
I have tried LiveUSB/LiveCD with Ubuntu 9.10 using dd to an .img file, but when I restore it on the new fit-PC2 I get a Out of Memory Grub error when it boots.
Any advice would be appreciated.
Denis
Re: How do I Clone one fit-PC2 to another
Post by Denis »
1. Check if disk you cloning is indeed your 8GB SSD and not LiveUSB by mistake.
2. Supposing your SSD is /dev/sda:
- Clone whole disk (/dev/sda) and not partition (/dev/sda1)
sudo dd if=/dev/sda of=8GB.img bs=1M
- Restore disk from image:
sudo dd if=8GB.img of=/dev/sda  bs=1M
