2.5" SATA II SSD work?
joshswenson
Post by joshswenson »
I would like to purchase a fit-pc2, but I would like a solid state hard drive with Windows 7. I don't see this as one of the options, so I'm considering purchasing the "fit-PC2i 2GB/2GHz Diskless" and purchasing a larger solid state hard drive that will accommodate the OS size of Windows 7. I'm trying to figure out if the following hard drive will work with the fit-pc2. Any ideas or suggestions?
Patriot Inferno PI60GS25SSDR 2.5" 60GB SATA II MLC Internal Solid State Drive (SSD)
http://www.newegg.com/Product/Product.a ... -_-Product
Re: 2.5" SATA II SSD work?
The majority of SSDs work with fit-PC2. We haven't tested this specific model.
yogev_ezra
Post by yogev_ezra »
I have this exactly disk and would be happy to test it for you on weekend.
Please wait here for update from me.
yogev_ezra
I tested this disk for a few hours and did not find any issues so far - the disk seems to be working fine. Here are CrystalDiskMark results on Windows XP:
CrystalDiskMark 3.0.1 (C) 2007-2010 hiyohiyo
Crystal Dew World : http://crystalmark.info/
* MB/s = 1,000,000 byte/s [SATA/300 = 300,000,000 byte/s]
Sequential Read : 87.637 MB/s
Sequential Write : 57.875 MB/s
Random Read 512KB : 86.846 MB/s
Random Write 512KB : 57.451 MB/s
Random Read 4KB (QD=1) : 15.373 MB/s [ 3753.1 IOPS]
Random Write 4KB (QD=1) : 10.014 MB/s [ 2444.8 IOPS]
Random Read 4KB (QD=32) : 16.852 MB/s [ 4114.2 IOPS]
Random Write 4KB (QD=32) : 10.651 MB/s [ 2600.3 IOPS]
Test : 1000 MB [C: 5.8% (6.4/111.8 GB)] (x5)
Date : 2011/01/17 0:40:39
OS : Windows XP Home Edition SP3 [5.1 Build 2600] (x86)
joshswenson
Awesome! Thanks!
Josh
shestero
Post by shestero »
Does fit-PC2 controller support TRIM command for SSD?
No. The native controller in US15W chipset is IDE - connected to hard disk through a SATA bridge so TRIM is not supported.
cbgoodbuddy
Post by cbgoodbuddy »
My understanding is that TRIM mode can work with an IDE controller.
My testing of a fit-pc2, with an SSD drive that supports the TRIM function, is that the TRIM function *does* work. The test shows that after deleting a file, it is automatically reset to all-zero, which indicates that the TRIM function is working.
More information:
http://www.fit-pc2.com/forum/viewtopic.php?p=8854#p8854
Craig
Return to “Storage”
