Question for the SSD Hard Drive !!!
Nicole
Post by Nicole »
I have a Question for the SSD Hard Drive in FitPC2 with 2 Ghz.
How hot is the FitPC2 with the SSD Hard Drive?
And how hot the unit to a normal Hard Drive?
If the SSD Hard Drive from the FitPC2 Supports 2GB 2Ghz?
Is the Performance with a SSD Hard Drive to remember in the FitPC2?
Thanks in advance.
Re: Question for the SSD Hard Drive !!!
SSD normally runs cooler than HDD and has better temperature tolerance.
SSD can work with any amount of RAM and any CPU speed.
Nicole
Post by Nicole »
Thank you for your reply.
Is a difference of SSD to remember to normal Hard Disk?
What's better Temperature?
If the FitPC with SSD only lukewarm?
Or just as hot as a normal Hard Drive?
Thank you.
Nicole
RKz
Post by RKz »
An SSD will always run cooler thsn a rotating disk contributing to lower temperature.
But more important, a standard SSD is specified to +70 deg C operational.
If you buy an industrial SSD it is specified to +85.
Also remember that all SSD:s are not alike. There are good ones, and lousy ones.
Richard Klingspetz
System Technology Sweden AB
Nicole
Post by Nicole »
Thanks for your Answer.
Can one say about how hot the FitPc with the SSD in the normal Operation is?
Approximate?
Ca. 40 degrees?
Thank you.
dadaniel
Post by dadaniel »
Nicole wrote:Thanks for your Answer.
Approximate?
Ca. 40 degrees?
Thank you.
HWMonitor reports CPU Temp of 55°C (idle) with Intel SSD
Nicole
Post by Nicole »
Thank you.
I have a Question for the SSD Hard Drive.
Does the Fit PC 2, the SSD Hard Drive?
It reads very much that you should switch to AHCI in the BIOS.
If the Fit PC 2, this Option?
Thanks in Advance
fit-PC2 and fit-PC2i support 2.5" SATA SSDs.
Nicole
Post by Nicole »
Can you make in the Bios of the PC 2 Fit the AHCI Setting?
I have read that it is very important that we understood the contents in the BIOS Setting selected.
If you do not Disse setting surrounded in the BIOS, the SSD Hard Drive is very fast Death.
Nicole
Post by Nicole »
Please Help me.
Return to “Storage”
