SD to mini-SD adapter
yogev_ezra
Post by yogev_ezra »
For anyone interested, I found an adapter that should allow using any SD card in FitPC2's miniSD slot: http://www.ably.com.tw/pdt/viewpdt.asp? ... cat=OTHERS
Product Brief: Convert SD memory card to fit in MiniSD socket. Supports SD memory and SDIO cards (if the host supports SDIO). With 3cm of flexible cable.
Specifications:
* Mini-SD replacement board.
* 3 cm flexible cable design for easy use.
* One Secure Digital (SD) socket.
* Fully compatible with SD memory cards.
* Fully compatible with SDIO cards (if the host supports SDIO).
* Dimensions: 80 x 32 x 4 (mm).
Return to “Storage”
