first post and heat problem
LG1
Post by LG1 »
hello
this is my first post on this forum.
i got a fitpc2 1,6ghz
and when i use this unit with not more then 20% cpu use the harddrive gets up to 49 Celsius and the cpu over 53 celcius
at higher cpu the temps get up to 58 HD and 63cpu.
i already got a second unit to replace this unit but with that unit it's he same.
now i read that there are a lot of poeple that have the same problem
i also read that on amazone? there is a heat sink?! any one got a link to that?
for a harddisk i use a WD3200Bevt at 5400 rmp.
i have place a fan on top of the unit with a little bit of space between
and now temps are fin. 41 for hd and 43 for cpu
but al of this end my silent server and ads 1,6watt ( the fan ) to the power consumption :(
Re: first post and heat problem
The heat-sink is available at http://www.amazon.com/Heatsink-for-fit- ... 411&sr=1-8
The CPU temperature is OK. To check about hard-disk temperature see hard disk specifications. Some hard-disks are rated for 60C.
LG1
Post by LG1 »
irads wrote:The heat-sink is available at http://www.amazon.com/Heatsink-for-fit- ... 411&sr=1-8
this harddisk is rated for 60c do you know about or use hd that aare rated for higher in your fitpc2 with hd pre installed?
The hard disks we are using probably generate less heat. Their temperature under load rarely exceeds 50C.
LG1
Post by LG1 »
irads wrote:The hard disks we are using probably generate less heat. Their temperature under load rarely exceeds 50C.
can you maybe tell what brand and type your using?
i have the WB3200BEVT
Hitachi HTS545016B9A300
LG1
Post by LG1 »
irads wrote:Hitachi HTS545016B9A300
ok thats something else
the WD3200bevt uses 2.5watts when running and your hitachi is using only 1,4 watts
i do have a 320gb so more to spin around i guessing.
Damike5646845646
Post by Damike5646845646 »
Solution for my Fitcp2I to pick a cooler on it all that you need is: 1x Tube heat sink compound 10ml, Cleaning alcohol 3ml,
1X heat sink compound glue -> http://www.reichelt.de/?ARTICLE=38063;PROVID=2028 , 1x Cooler some like that -> http://www.reichelt.de/?ACTION=3;GROUP= ... ee0f7b54c5 or -> http://www.reichelt.de/?ACTION=3;GROUP= ... ee0f7b54c5
Work: Well you have to clean all surface with alcohol then take the cooler and put the heat sink compound on the survace but let on each korner aprox 1cm x 1cm free of heat sink compound that space is for the " two component heat sink glue" to fix the cooler on the fit pc.
Result: I made a 5 hour cpu test the max temp -> 37°C
Idle Temp -> 28-29°C
Room Temp -> 22°C
Design: Well .... you must like it, but it works.. :)
Dominik
Post by Dominik »
I'm using the original heat-sink for fit-pc2 without heat sink compound/glue. I ordered it from sh-edv-vertrieb.de.
/dev/sda: SAMSUNG HM641JI: 32°C
CPU core: 50-51 C, CPU surface: 43 C
Return to “Power and Heat”
