Can I use PoE Splitter as a power supply of fit-PC2i?
mandy
Post by mandy »
I have bought a fit-PC2i. Can I use PoE Splitter as a power supply of fit-PC2i? Thank you!
RKz
Re: Can I use PoE Injector as a power supply of fit-PC2i?
Post by RKz »
A POE-Injector applies 48 VDC over the Ethernet cable. In the other end you need a POE-splitter that can provide 12 VDC with enough power.
Look at this one as an example. It provides 1 A @12 VDC so it should work for a fit-PC.
http://www.l-com.com/item.aspx?id=9506
Note that this might not be true if you add peripherals on USB.
Richard Klingspetz
System Technology Sweden AB
Return to “Power and Heat”
