USB over-current change errors & disconnects
rambler
Post by rambler »
I have two USB devices connected to my fit-pc2 - a Current Cost power monitor and a weather station. After about 12-24 hours I get messages like this in syslog:
hub 4-0:1.0: over-current change on port 1
hub 1-0:1.0: over-current change on port 1
hub 1-0:1.0: port 2 disabled by hub (EMI?), re-enabling...
They are directly connected to the rear USB ports of the fit-pc2, not through a hub and it happens with both devices.
I moved one to a desktop PC running the same latest CentOS 5.4 kernel version and it's been running fine now for 2 days so it confirms the problem is with the fit-pc2.
Any ideas?
t40t40
Re: USB over-current change errors & disconnects
Post by t40t40 »
Hi
I think I see someting like you!
I use a Usb smartcard reader based n FTDI chipset.
If I do a reboot with that in the system, The application just go crasy. I cant even kill the process.
If I boot the FIT with out The reader and plug it in later everything works fine.
I run Ubuntu 9.10
I use to run the same setup on am older IBM T23. The problem was not there.
Please guide me to send you some logfiles.
T40T40
Return to “Linux on fit-PC2”
