Hard Disk issues in Debian
nefeli
Post by nefeli »
I installed Debian Squeeze on my fit-pc2. All runs ok, so each time I try to fsck a large partition in the internal hard disk, I get this errors:
[  394.301711] ata1.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x6
[  394.301822] ata1.00: BMDMA stat 0x24
[  394.301913] ata1.00: cmd c8/00:80:31:09:c4/00:00:00:00:00/eb tag 0 dma 65536 in
[  394.301916]          res 51/84:3c:75:09:c4/00:00:00:00:00/eb Emask 0x10 (ATA bus error)
[  394.302113] ata1.00: status: { DRDY ERR }
[  394.302187] ata1.00: error: { ICRC ABRT }
[  394.302294] ata1: soft resetting link
[  394.481016] ata1.00: configured for UDMA/33
[  394.481164] sd 0:0:0:0: [sda] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[  394.481290] sd 0:0:0:0: [sda] Sense Key : Aborted Command [current] [descriptor]
[  394.481559] Descriptor sense data with sense descriptors (in hex):
[  394.481678]         72 0b 47 00 00 00 00 0c 00 0a 80 00 00 00 00 00
[  394.482469]         0b c4 09 75
[  394.482749] sd 0:0:0:0: [sda] Add. Sense: Scsi parity error
[  394.482917] end_request: I/O error, dev sda, sector 197396785
I've received the fit-pc2 a few days ago, so I think it should not be the hard drive (I still need to test it). Can anyone help me?
Thank you very much in advance
prj
Re: Hard Disk issues in Debian
Post by prj »
I have similar problems. I'm running Ubuntu Server 9.04. I saw that my system was running a bit warm (~60 C) so I put the unit on the edge. This lowered the average temp by ~5 C and the problem went away.
Could be a coincident but it is worth a try.
nefeli
Post by nefeli »
Thank you very much. I've tested what you said and still get the same error, with kernel version 2.6.26 and 2.6.30. I've asked SMART with skdump and reported 2 bad sectors, so I'm going to test the hard disk with the Hitachi suite.
Return to “Linux on fit-PC2”
