Operating Temperature with SSD
Issues specific to fit-PC2i
dcsmith
Post by dcsmith »
First off - WOW! This is great! I now have two applications that can be met with the Fit-PC2i. However, I noticed that the operating temperature of the PC with an SSD is <up to> 70 deg C. That's 158 deg F! Isn't that a bit on the warm side? I'd hate to have to jury rig a cooling system on such a neat tiny package.
halestorm
Re: Operating Temperature with SSD
Post by halestorm »
dcsmith wrote:First off - WOW! This is great! I now have two applications that can be met with the Fit-PC2i. However, I noticed that the operating temperature of the PC with an SSD is <up to> 70 deg C. That's 158 deg F! Isn't that a bit on the warm side? I'd hate to have to jury rig a cooling system on such a neat tiny package.
Wow is right! :o
I didn't catch that (and I just ordered a FitPC2 + SSD). That is the temperature needed to fry an egg! http://www.loc.gov/rr/scitech/mysteries/friedegg.html
Great, now I have to add a fan to my "fanless" computer. :x
Dave
http://evalbum.com/2500
almost no reason to burn gasoline anymore
fit-PC2 does not generate heat that results in 70C, it can withstand working at temperature of 70C when equipped with SSD rather than HDD.
dcsmith
Post by dcsmith »
:mrgreen:
Thanks for the clarification. I was worried.
Why the difference in heat tolerance between SSD & HDD?
HDDs are usually rated for only 55 to 60C. Magnetic media is less reliable at high temperatures.
dcsmith
Post by dcsmith »
Makes sense. You might want to clarify the temperature tolerance in your specs. I got confused. Others might as well. :?
Return to “fit-PC2i hardware”
