custom kernel
Re: custom kernel
Hmm..
Drm and psb sources available under drivers/char/drm.
Squashfs and unionfs from Ubuntu distribution indeed not in our release but available here
http://archive.ubuntu.com/ubuntu/pool/m ... .39.tar.gz
Re: custom kernel
This is what I am using:Denis wrote:Hmm..
linux_2.6.24.orig.tar.gz
linux_2.6.24-34.7.diff.gz
Drm and psb sources are not there. Perhaps they are on your your hard drive - that I can't see. But they are most certainly not included in those two files.
And they will work with your distributed kernel with the strange rt_* symbols?Squashfs and unionfs from Ubuntu distribution indeed not in our release but available here
Carl
Re: custom kernel
I suppose I could be wrong, but I assumed this:Denis wrote:linux_2.6.24.orig.tar.gz from our website?
http://fit-pc2.com/download/ubuntu/dists/hardy/source/
was your web site. If that is wrong, where can I get the the source that you mentioned that does include drm/psb?
Ok, this is source that apparently lives outside the kernel tree, in:Squashfs and unionfs from Ubuntu distribution indeed not in our release but available here
lum/ubuntu/media/drm-poulsbo/
and
lum/ubuntu/fs/squashfs/
Can you please tell me what to do with that? I mean where do I burst the tar ball and how do I get it stitched into the kernel build? The patch doesn't appear to do that and the Makefiles are clearly not stand alone.
Carl
Re: custom kernel
Yes, http://fit-pc2.com/download/ubuntu/dists/hardy/source/ is our site. All you need is linux_2.6.24.orig.tar.gz and linux_2.6.24-34.9.diff.gz. Config file under debian/config/
Are you sure there is no any *psb* file under drivers/char/drm? Please post what do you have under this folder
Re: custom kernel
I used /proc/config.gz from a running system generated by following these directions from your site (http://fit-pc2.com/wiki/index.php?title ... buntu_8.04) It is identical to /boot/config-2.6.24-34-fitpc2 from the same system - is that wrong? I do not find any debian/configDenis wrote:Yes, http://fit-pc2.com/download/ubuntu/dists/hardy/source/ is our site. All you need is linux_2.6.24.orig.tar.gz and linux_2.6.24-34.9.diff.gz. Config file under debian/config/
Here you go:Are you sure there is no any *psb* file under drivers/char/drm? Please post what do you have under this folder
ati_pcigart.c drm_sarea.h mga_drm.h savage_bci.c
drm_agpsupport.c drm_scatter.c mga_drv.c savage_drm.h
drm_auth.c drm_sman.c mga_drv.h savage_drv.c
drm_bufs.c drm_sman.h mga_ioc32.c savage_drv.h
drm_context.c drm_stub.c mga_irq.c savage_state.c
drm_core.h drm_sysfs.c mga_state.c sis_drm.h
drm_dma.c drm_vm.c mga_ucode.h sis_drv.c
drm_drawable.c i810_dma.c mga_warp.c sis_drv.h
drm_drv.c i810_drm.h r128_cce.c sis_mm.c
drm_fops.c i810_drv.c r128_drm.h tdfx_drv.c
drm.h i810_drv.h r128_drv.c tdfx_drv.h
drm_hashtab.c i830_dma.c r128_drv.h via_3d_reg.h
drm_hashtab.h i830_drm.h r128_ioc32.c via_dmablit.c
drm_ioc32.c i830_drv.c r128_irq.c via_dmablit.h
drm_ioctl.c i830_drv.h r128_state.c via_dma.c
drm_irq.c i830_irq.c r300_cmdbuf.c via_drm.h
drm_lock.c i915_dma.c r300_reg.h via_drv.c
drm_memory.c i915_drm.h radeon_cp.c via_drv.h
drm_memory_debug.h i915_drv.c radeon_drm.h via_irq.c
drm_memory.h i915_drv.h radeon_drv.c via_map.c
drm_mm.c i915_ioc32.c radeon_drv.h via_mm.c
drm_os_linux.h i915_irq.c radeon_ioc32.c via_verifier.c
drm_pci.c i915_mem.c radeon_irq.c via_verifier.h
drm_pciids.h Kconfig radeon_mem.c via_video.c
drmP.h Makefile radeon_state.c
drm_proc.c mga_dma.c README.drm
Re: custom kernel
I understand your confusion. I started over from scratch, downloading those two files again, bursting, patching, and I find *psb* in drivers/char/drm. I also find debian/config/i386/config.fitpc2 that matches the one I used earlier. I certainly don't understand this, but will now go away and try again.Denis wrote:Yes, http://fit-pc2.com/download/ubuntu/dists/hardy/source/ is our site. All you need is linux_2.6.24.orig.tar.gz and linux_2.6.24-34.9.diff.gz. Config file under debian/config/
I haven't dealt with vendor specific kernel patches before. Would "make clean" or "make mrproper" wipe out any of your patches?
Carl
Re: custom kernel
Denis,
By starting again from scratch with linux_2.6.24.orig.tar.gz and linux_2.6.24-34.9.diff.gz I can compile a kernel with drm_psb and psb modules.
I can patch the source for squashfs and compile cleanly.
A compile after patching for unionfs fails because of a difference between nrpages and __nrpages. Your sources have a different include/linux/fs.h than 2.6.24.2 from Ubuntu and 2.6.24 from kernel.org. Why is this? How do I get past this? Can I apply your -34-fitpc2 diffs to 2.6.24 from kernel.org?
Carl
Carl
Re: custom kernel
That isn't useful. Neither 2.6.24 from kernel.org nor 2.6.24.2 from Ubuntu have the *psb* stuff.gearheadgeek wrote:Can I apply your -34-fitpc2 diffs to 2.6.24 from kernel.org?
Carl
Re: custom kernel
Why you do not try Ubuntu 9.04? Drm, psb, unionfs, squashfs included in kernel sources already
