i've got two questions about the new fit-pc.
1. Does w/o wifi in the "fit-PC2 Diskless" and "fit-PC2 Linux Value" configurations truly mean without any wireless lan support/chipset or just delivered without an antenna?
2. Is the miniSD socket SDHC compatible?
Konrad
WLAN and miniSD socket
Re: WLAN and miniSD socket
The WLAN is implemented as a mini-PCI express card and is not installed in the diskless and value models to reduce costs. This is not intended for user installation but 1.1GHz with WLAN may be offered by distributors.
Unfortunately the SD controller in US15W does not support SDHC.
Is the port/socket for the WLAN PCI-E Card still available in diskless and value configurations (for adding wlan functionality on my own - and no usb devices suck
)? Unfortunately my local distributor just ships the standard versions of fit-PC2, but I really don't need the 160gb non-flash drive because I want the system to be highly energy efficient (and of course I don't want to pay for a spec I won't need).
konrad,
thank you for asking the question. My mini SD cards are all over 4GB, so fit-pc2 is unusable for me. I will wait for fit-pc3.
@amite.rivers
maybe you think about using an usb adapter. some of them are very tiny and support sdhc without any problems. at least for me waiting for fit-PC2 is not an option
Does "not intended" also mean "not possible" or can I buy a diskless or value configuration and add something like this:irads wrote:The WLAN is implemented as a mini-PCI express card and is not installed in the diskless and value models to reduce costs. This is not intended for user installation but 1.1GHz with WLAN may be offered by distributors.
http://shop.varia-store.com/product_inf ... -5GHz.html
Not intended means that we may manufacture fit-PC2 that does not incorporate WiFi functionality without the miniPCI express socket.
The specific miniPCI express you linked to is half size. We support full size.
Anyway opening fit-PC2 to install another miniPCI express card is considered hacking and will void your warranty.
Please note the card you have specified is a Mini PCI....... or can I buy a diskless or value configuration and add something like this:
The Fit-PC2 has a miniPCI express card.
It is not the same.
See the following link as an example Mini PCI express:
ThinkWiki intel 3945 adapter
I wonder if Mini-PCI-Express slot can be used to install BlueTooth adapters for those who want internal BlueTooth adapter and don't want Wi-Fi functionality.
Accessing the miniPCI Express slot involves factory disassembly and is not covered by warranty.
