I have had my fitPC2 running since September 24/7 without missing a beat until yesterday.
It appears we lost power overnight and on checking my fitPC2 had not completed its re-boot.
The bootup starts okay and I think nearly finishes as it gets to the following position in the boot up sequence ...
Loading essential drives .... ok
Running /scripts/local-premount ok
Mounting root file system ...
Running /scripts/local-top ok
Running /scripts/local-bottom ok
Running /scripts/init-bottom
Starting AppArmor profiles
after about 25secs the following is displayed
(some text dealing with USB configuration)
and ends with ...
init:ureadahead main process (383) terminated with status 5
[The number in brakets changes on each attempt at cold restart]
What do I need to do to access the fitPC2 to correct this problem or does it require a complete re-installation of Ubuntu 9.10 ?
Thanks for your help.
Boot Problems Ubuntu 9.10
