I'm trying to force my machine to boot in 1360x768 every time, even when there's no monitor attached or turned on. I've added GRUB_GFXMODE=1360x768 to /etc/default/grub and ran sudo update-grub
I've also made sure that /etc/X11/xorg.conf has Modes "1360x768" as the only mode line in the Section "Screen" area.
However, if I boot up with the monitor turned off or unplugged it boots up in 1920x1200
Can anyone tell me how to force Ubuntu 9.10 to boot up in a specified resolution regardless of what monitor is attached or not.
Force Display Resolution in Ubuntu 9.10
Re: Force Display Resolution in Ubuntu 9.10
Actually, I don't have any helpful tipps or even a solution. However, could that be related to the fact, that gma500 disables itself when there is no display present? This behavior kicks in even if a display is connected, but not powered. At least this is, what the specs tell
That's odd. The XP IEGD driver will boot into a specified resolution even when not connected to a powered display.
Well, I was just guessing. Does the xorg.log (or the error log?) provide any information?
--edit--
GRUB_GFXMODE can only use with vesa modes by the vesa bios extension. You can check available modes using vbeinfo in the grub command line (press c in grub menu). On my fitpc2 this gives me the following modes: 1600x1200 1280x1024 1024x768 800x600 640x480
However, this should in no way be related to your actual X resolution. Could you please post your xorg.log? You might try to use 1024x768 which are more common dimension. If this works, but your one not, you might want to set up an xorg.conf using 1920x1600 with a smaller virtual screen inside.
--edit--
