Power socket connector detached
Power discussions, CPU and case temperature
gentlemich
Post by gentlemich »
After using the Fit-PC2 just once, I put the power supply connector into its socket on the Fit-PC2 but now the socket has been detached/disconnected from the board...
I have been trying to resolder it by hand on the board but it's a bit tricky (because of the location). Do you have any idea of what I can do?
Is there still a warranty? I bought the PC in November 2009 on Amazon.
Mic
fly
Re: Power socket connector detached
Post by fly »
Opening the case (except for the HDD slot) and resoldering will most likely void the warranty. So it's up to the good will of amazon and/or compulab how they handle a RMA procedure. For details you should ask amazon.
Please email rma@fit-pc.com
I hope the soldering did not cause extra damage to the motherboard.
Return to “Power and Heat”
