No 1Gbps Ethernet
No 1Gbps Ethernet
i cant get 1gbit connection but my hardware support it switch (8 port gigabit) fitpc2I (Gigabit) LAN-wire cat.6 what is wrong? any solution?
Re: No 1Gbps Ethernet
The Ethernet ports of fit-PC2i do support 1Gbps. Please provide more details -
Is stated link 100Mbps or 1Gb
Which OS you are using
What is the actual rate you are seeing
My OS id windows7 pro my switch is a Netgear GS108 ->Link http://www.netgear.de/Unternehmen/Switc ... index.html
my older PC does support 1GBIT on that port so it can't be a wiring mistake.
What is the actual rate you are seeing? What you mean? my transfer rate from one pc to an other is about 5,6MB/sek thats poor...
- Network2.jpg (35.28 KiB) Viewed 10114 times
- Network.jpg (85.78 KiB) Viewed 10115 times
Hi.
The speeds you encounter were probably more a factor of the hard drives being used than the network connection.
For more information, please read the following article:
http://binglongx.spaces.live.com/blog/c ... =259621805
Leonid Firdman
