I have downloaded the IEGD software : http://edc.intel.com/Software/Downloads/IEGD/
I can't manage to produce a functional driver for XP for my display : depending on options I choose in the IEGD software, either resolution 1680x1050 doesn't appear in the list for display configuration or driver is not functional (means I have a black screen at Windows opening and no signal sent to display).
In IEGD I manage to create a new DTD (see screen copy attached).
I then create a new configuration :
Parameters for the 1st page of IEGD configuration editor : single display, enable display detection, port order : sDVO and then LVDS (see screen copy).
Parameters for 2nd page of IEGD configuration editor : all check boxes ticked for EDID option but I don't know what to parameter for DVO devices, attribute settings so I ticked every choice ...
I didn't filled any option in the attributes pages ... perhaps it is an error ??
XP driver for 1680x1050 display / IEGD Driver
- sDVO configuartion Page : no attributes settings set
- NewConfp2.jpg (60.02 KiB) Viewed 45016 times
- New Configuration Page 1
- NewConfp1.jpg (48.93 KiB) Viewed 45017 times
- New DTD for Display 1680x1050
- NewDTD.jpg (56.41 KiB) Viewed 45017 times
Re: XP driver for 1680x1050 display / IEGD Driver
Last screen copy for LVDS configuration (no attributes settings have been parametered).
Page 4 and 5 of configuration set up attached ...
- New configuration page 5 and last
- NewConfp5.jpg (75.45 KiB) Viewed 45012 times
- New configuration Page 4
- NewConfp4.jpg (29.44 KiB) Viewed 45012 times
- NewConfp3.jpg (59.12 KiB) Viewed 45012 times
I have then produced a new package with my configuration and target OS : XP/XPe.
Result is not working : black screen at windows opening : no signal detected by my display.
FitPc2i works pretty well and the only issue regards this display driver problem.
Hope you can help.
Best regards.
MyConf : Fit Pc2i (Nr-100521-051) - WinXP Pro SP3 - display Fujitsu Scaleoview H22w-1
Hope you can help.
Best regards.
- NewPackage.jpg (51.63 KiB) Viewed 45006 times
IEGD driver generator is beyond the scope of our support. I will try to provide a few tips - but I am not an expert on that. For more details consult IEGD documentation.
fit-PC2 is using only the SDVO interface with a Chrontel CH7307 DVI transmitter. LVDS interface is not used. Settings in IEGD should be chosen accordingly.
Attached please find reference IEGD configuration file for fit-PC2 you can start with. First generate a driver and see it is working, then modify configuration as per your needs.
- fit-PC2_IEGD_10.3.cnfg.zip
- (1.39 KiB) Downloaded 921 times
