Well, there it is, server 2003 R2 SP2 system residing in 8GB CF-SSD.
performance is poor because CF (133x) isn't too fast even with UDMA4.
RamDisk increases it a lot! Remember to change /temp references to here!
GFX drivers had to install as SVGA adapter driver update via "I'll give you the location" dialogs, where you really give location.. Drivers are at LPCO/ root in the xp-driver package.
is this correct way to install GMA500 drivers? At least Display properties says GMA500 acceleration but there is no "controll panel"..
EDIT: Enable acceleration in troubleshoot displayproperties.
Still I remember to see 2 PCI-Devices without drivers in DeviceManager.. after aLL chipset drivers, lan etc....
what are those?
EDIT: 2 unknown PCI device problem is solved in some thread here.
