fitlet2 serial port naming for centos 7
Moderator: Andrey.Mazlin
liorK
Post by liorK »
do you have a solution to activate fitlet2 serial com port on centos 7 ?
Andrey.Mazlin
Re: fitlet2 serial port naming for centos 7
Post by Andrey.Mazlin »
liorK wrote:
Thu May 21, 2020 3:18 pm
Did you try this?
Let's open up our text editor: nano /etc/sysconfig/grub.
Find the line labeled GRUB_CMDLINE_LINUX and add console=ttyS0 to the end (this assumes your serial port is ttyS0). ...
Save the file and exit.
Run
stty -F /dev/ttyS0 speed 9600
Then
grub2-mkconfig -o /boot/grub2/grub.cfg
Finally
systemctl start getty@ttyS0
Andrey Mazlin,
Edge Computers Department Application Support Engineer
Useful links:
Main site: https://edge.compulab.com/
Support mail: edgesupport@compulab.co.il
