fit-PC 2i Not starting up
Is fit-PC2 good for my intended application?
Umesh
Post by Umesh »
I have an issue with the fit-pc2i 2GB/1.6 GHz Diskless - which is not starting up.Only power LED is lit.Anyone can share some troubleshooting info?
Umesh
tamir
Re: fit-PC 2i Not starting up
Post by tamir »
It is worth trying to follow the troubleshooting guide:
http://fit-pc.com/wiki/index.php/Fit-PC ... leshooting
Additionally, if the power LED is lit, perhaps it a case where there's no display output?
Are there more LED indicators, such as Numlock on the keyboard when the PC is on ?
Check the monitor setup including cable, also worth checking another RAM stick.
Umesh
Post by Umesh »
Thank you very much for the reply.There is no display when connected to monitor.Only power LED is lit.
The link provided didn't help.Is there anything else / other ways we can check further?
Thank you very much in advance.
Look forward to the reply.
fitpc Image.jpeg (59.59 KiB) Viewed 7333 times
tamir
Post by tamir »
What about these?
"Are there more LED indicators, such as Numlock on the keyboard when the PC is on ?
Check the monitor setup including cable, also worth checking another RAM "stick.
Did you try another RAM module ?
Does the Numlock respond when you click it when the machine is on?
Return to “Using fit-PC2”
