Hello, I have a fit PC2i bought a few years ago and it does not want to boot anymore.
I unplugged it from electricity, pushed the power button for 1mn to drain capacitors but I was unsuccessful.
As soon as the power is plugged the power light comes up, the Ethernet ports lights are on, and the HDMI says link switch from "No input" (when the PC is off) "no signal" when powered. Then nothing; the unit just heat.
Have you ever encountered this situation ?
Thank you.
Fit PC2i does not boot
Issues specific to fit-PC2i
Re: Fit PC2i does not boot
Little follow-up; the problem is fixed.
It seems the bios got corrupted.
I did follow these steps to reset CMOS and it finally booted :http://www.fit-pc.com/wiki/index.php/Fi ... leshooting
Cheers!
Cheers!
