Windows 7 and Watchdog timer
Leonid
Re: Windows 7 and Watchdog timer
Post by Leonid »
Hi.
Please send me the file c:\Watchdog\instlog.txt
Leonid Firdman
Zibeo
Post by Zibeo »
Here's the contents of instlog.txt:
watchdog.exe OK
watchdogCMD.exe OK
readme.txt OK
test.bat OK
freeze.exe OK
Ntport.dll OK
sc.exe OK
pathman.exe OK
zntport.sys OK
HKLM\SYSTEM\CurrentControlSet\Services\zntport ImagePath OK
HKLM\SYSTEM\CurrentControlSet\Services\zntport DisplayName OK
HKLM\SYSTEM\CurrentControlSet\Services\zntport Type OK
HKLM\SYSTEM\CurrentControlSet\Services\zntport Start OK
HKLM\SYSTEM\CurrentControlSet\Services\zntport ErrorControl OK
HKLM\SYSTEM\CurrentControlSet\Services\zntport Enabled OK
HKLM\SYSTEM\CurrentControlSet\Services\zntport Time OK
watchdog service OK
pathnam command OK
Zibeo
Post by Zibeo »
BTW, the XP watchdog driver and watchdog.exe seem to work in Windows 7 however if the watchdog timer is reset more than once quickly (under 2 seconds) the PC powers off and stays off. My Fit-PC2's are first generation with auto-on. I have multiple units and they all exhibit this same behavior.
Leonid
Post by Leonid »
Hi.
I need some clarifications:
1. What OS do you use?
2. What version of Watchdog do you use?
You can check it by typing 'watchdogcmd help' in command prompt
Leonid Firdman
Zibeo
Post by Zibeo »
Windows 7 Professional, and the latest version of the watchdog timer 2.1 which is downloadable in this thread.
ddragish
Post by ddragish »
IS Watchdog Timer 2.1 posted in this thread still the latest for FitPC2 running Win7 Pro 32-bit?
FitPC does not post this driver online under Software Rep for FitPC2.
However the IntensePC watchdog timer is posted for Win 7 Pro 32-bit.
Intense-PC_Win7_Watchdog_2013.06.19.zip
I installed this driver on the FitPC2 and it does not work?
Watchdog is timing out and resetting PC everytime with cmd enabled.
Help please, thanks!
You can turn the watchdog off in BIOS
Return to “Windows 7”
