Audio Problem - Intense PC
Re: Audio Problem - Intense PC
No, there is no registry patches.
You should see something like this on your playback devices tab
Dou you have other HDMI device for testing purposes?
JuTs
Post by JuTs »
I have the same problem. No sound on analog output (I can't test with digital). But it's like it has not detected that I pluged the speakers.
Julien
Dear Julien
If you want to get an analog audio output, you should apply this patch.
Intense-PC_Audio_Patch.zip
(369 Bytes) Downloaded 932 times
The enclosed patch can be also found in the Intense PC audio driver directory
JuTs
Post by JuTs »
gabrielh wrote:Dear Julien
That doesn't work.
I also tried with an HDMI device and I get the same result
Julien
No, sorry. Windows will enable HDMI sound output once it'll recognize a valid HDMI connected device.
JuTs
Post by JuTs »
Hi
You're probably right for the the HDMI device. It's the first time I try to use it for sound.
I try to re-install my system (I have a backup of the system). So I started from a fresh install. I installed the patch, the drivers but nothing better. It's like the system doesn't detect that I plugged a device.
Julien
JuTs
Post by JuTs »
I tried something else :
I'm using Windows 8. I thought that could be the problem. So I tried to install Windows 7. But still no sound. Il also try to install the last driver from realtek website.
Julien
Dear Julien
Intense PC uses Intel's driver for the HDMI connection. Once you connect an appropriate HDMI device, it should be recognized by the OS as a sound device.
Please try a live Linux Mint OS to see if you have an HDMI sound output
JuTs
Post by JuTs »
I'm trying to get analog sound. for HDMI it was just a try to check if it works.
But I will try with Mint
JuTs
Post by JuTs »
With Mint 14 I have analog sound.
Julien
Return to “Audio”
