Audio In/Out jacks reversed?
csimon
Post by csimon »
I've just spent some time trying to get analogue audio out working, and I notice that a lot of other people have had a similar problem. But I got it working by plugging the cable into the inner/right audio socket instead of the outer/left one. The inner/right socket is labelled as Audio In in the User Guide. Is the User Guide wrong or has my Intense PC been wired up incorrectly??
RKz
Re: Audio In/Out jacks reversed?
Post by RKz »
If you look at the marking on the bottom of the IPC you will see that Audio Out is marked correctly. So the Users Guide should be changed.
Richard Klingspetz
System Technology Sweden AB
csimon
Post by csimon »
RKz wrote:If you look at the marking on the bottom of the IPC you will see that Audio Out is marked correctly. So the Users Guide should be changed.
Ah, I didn't think to look underneath!
Return to “Audio”
