Analog output in Ubuntu 12.10
mandor
Post by mandor »
Hi
Did someone test the analog output (or the S/PDIF output) on Linux? I installed Ubuntu 12.10 and I can't hear anything. Do I need to do something special (except selecting the duplex output in pavucontrol)?
[the HDMI sound is working]
Thank you for your help,
-- mandor
mandor
Re: Analog output in Ubuntu 12.10
Post by mandor »
I solved my issues (and am much happier now).
The (printed) manual was wrong: the audio in and out were swapped. I don't know if it's specific to my unit (intense-pc celeron).
-- mandor
eladn
Post by eladn »
I tried Ubuntu 13.04 (on intense-pc core i7) and the analog sound doesn't work either. I tried both left and right ports.
Can you please share how you solved your issues?
Open alsa-base.conf file
nano /etc/modprobe.d/alsa-base.conf
And add this line to the bottom:
options snd-hda-intel model=generic
Restart the computer. Open the sounds settings. You will see now the analog sound as one of the options
eladn
Post by eladn »
It worked!
Thank you very much.
Return to “Audio”
