mSATA support
Posted: Wed Feb 06, 2013 10:30 pm
by weberitc
I bought an Intense PC (Value/847E) last month at your german distributor Extra-Computer/exone. It's working fine so far....
Now I'd like to use an mSATA-SSD in the full-size PCIE-slot.
The serial number of my Intense PC ist 1121118-00110. The BIOS Version is CR_2.2.0.346 X64 (11/25/2012).
Is mSATA fully supported by this revision of Intense-PC? There are several mSATA options in the BIOS, but after what I've read in the forum, I'm not sure, if the hardware is capable...
Thanks, Martin
Re: mSATA support
Posted: Fri Feb 08, 2013 9:51 am
Correction to my answer from 8-Feb: mSATA support in HW revision 1.1 that you have is limited. You will need to disable Sleep mode.
You may use a SATA SSD with no such restrictions.
