New BIOS for Intense PC released - 10-Apr-2013
Re: New BIOS for Intense PC released - 10-Apr-2013
Unfortunately, the watchdog driver release postponed till the end of May.
vtailor
Post by vtailor »
I installed the new bios on my "bargain" intense-pc to make sure I left no stone unturned, and it sure looks spiffy with that picture of a motherboard and the full-screen effect. Now, if you guys would put it on your todo list, how about a bios item for enabling analog audio output detection?
Thanks in advance. Posted from Linux on the intense pc.
IntensePC_User
Post by IntensePC_User »
Hi Gabrielh and Leonid,
Do you have any update on the Windows watchdog driver?
Leonid
Post by Leonid »
Due to some unexpected technical difficulties we are forced to postpone the delivery of this feature. It will be released within 2 weeks.
Leonid Firdman
Leonid
Post by Leonid »
The Watchdog driver and application can be downloaded from our FTP:
http://www.fit-pc2.com/download/Intense ... .06.19.zip
Please, read the user manual before installation.
Leonid Firdman
actaea
Post by actaea »
I have ordered an Intense PC. In preparation for it, I'm making a usb stick with the new BIOS. It slightly concerns me that DOS_IMG.IMG writes a DosFlash.Exe file that is 304KB and then we are supposed to overwrite it with DOSFLASH.EXE that is 333KB. This is OK?
Yes, that is all right
jesmx00
Post by jesmx00 »
The BIOS file's MD5 sum which is published on the Web-Site seems to be wrong. When i
download the file and calculate the MD5-hash i get:
MD5 (IPC_BIOS_10-04-2013.ZIP) = 35b04e0fa9941be23aaae4c13feb1ef0
Could you please check?
Thank you,
Joachim Schneider
Fixed.
Thank you for your bug submission.
IntensePC_User
I'm trying to use the Windows watchdog timer driver and having a bit of trouble. I'm using the x86 driver on Windows 7 32-bit.
When trying to start the watchdog service using the recommended method i get the following error:
"Windows could not start the Watchdog service on Local Computer
Error 1068: The dependency service or group failed to start"
I get the same error when trying to start the watchdog service manually in the service control panel as well.
Any ideas on what the problem is?
Thanks.
Return to “Intense PC BIOS”
