IDE ATA/ATAPI Controllers issue
girotel
Post by girotel »
In the bios I have configured the option to boot SSD hard-disk with AHCI (legacy mode).
During the first cold boot of the bios the windows device manager shows the following in Windows 7 X64:
IDE ATA/ATAPI controllers
- ATA Channel 0
- ATA Channel 1
- Standard Dual Channel PCI IDE Controller (hardware Ids PCI\VEN_8086&DEV_1E3C&SUBSYS_72708086&REV_04)
- Standard SATA AHCI Controller (hardware Ids PCI\VEN_8086&DEV_1E03&SUBSYS_72708086&REV_04)
When I do a warm reboot the Standard Dual Channel PCI IDE Controller is gone (like it should be because I choose AHCI in bios)
The windows device manager then shows the following:
BIOS Version: CR_2.2.0.262 X64
Intense PC Pro Intel Core i7-3517UE
Hard-disk OCZ-VERTEX4 (hardware Ids SCSI\Disk_____________OCZ-VERTEX4_1.5)
Could this be corrected ?
Thank you.
girotel
Re: IDE ATA/ATAPI Controllers issue
Post by girotel »
Could you confirm that this issue exsists and replicate these results ?
Thank you
Dear girotel
This is a driver related issue. Because this is Intel's a closed source driver, we are unable to modify it.
girotel
Post by girotel »
Thanks for the response.
Software issue ?
Perhaps you could ask Intel to fix this problem ?
Never ever experienced these kind of issues on other computers.
With kind regards
Girotel
Good Day girotel
After several tests, there was not seen any performance differences between both of the cases. We will submit this issue to Intel.
Thank you for reporting.
girotel
Post by girotel »
Any Response from intel ?
Good evening.
Not yet. Sorry
Return to “Intense PC BIOS”
