USB3 disk boot
sirk
USB3 disk boot
Post by sirk »
Hello
I've just received my Intense PC.
The pc can't boot on internal drive if there is an USB3 disk pluged in...
If i remove it and plug it after it works.
Any idea ? :|
Thanks !
Re: USB3 disk boot
You should give the internal HDD the highest priority boot order in the BIOS menu.
sirk
Re: USB3 disk boot
Post by sirk »
It's already the case on the boot order menu.
At launch, Intel logo appears on the left and then ... nothing.
Re: USB3 disk boot
What is the model of your IntensePC?
sirk
Re: USB3 disk boot
Post by sirk »
It's an "Intense PC Value Barebone"
Re: USB3 disk boot
We will try to reproduce the problem and I report you back
Re: USB3 disk boot
I am unable to reproduce this issue on our side. The unit boots fine from both devices - the USB3 and from the internal SSD.
The setup includes Afaya SSD 32GB and Transcend 8GB USB3
What is your BIOS version?
What is the type of the USB3 device do you use?
sirk
Re: USB3 disk boot
Post by sirk »
My BIOS version is "CR_2.2.0.262 X64"
My external HDD is a Western digital 3TB.
Re: USB3 disk boot
We have confirmed this issue. The root of the issue is in the BIOS. We will release the BIOS update ASAP.
Please accept my apologizes for an any inconvenience that is issue caused you, and thank you for submitting this it
duane
Re: USB3 disk boot
Post by duane »
I imagine my problem is due to the same issue. I want to put /home on a USB3 disk, but it does not mount in time to be available after booting (though it is available later), so I cannot login.
Thanks, Duane
Return to “Intense PC BIOS”
