irq xx: nobody cared (try booting with the "irqpoll" option)
mostacholoco
Post by mostacholoco »
Hello. I've an Intense PC and I'e just upgraded from Debian 7 to Debian 8.
I'm randomly getting an error on boot that states:
irq 16: nobody cared (try booting with the "irqpoll" option)
The result is that when it finally boots the mouse pointer movement is considerably degraded: it moves extremely slow and as if it moved with low FPS, to put it some way.
I made same research about this and noticed kernel developers blamed the BIOS in similar scenarios. They also advised booting using irqpoll but in all cases everyone complained about system performance being extremely degraded.
This is the relevant snippet from my dmesg but I'm attaching it to the post anyway. I'm also attaching the output of "cat /proc/interrupts"
[    1.500876] usb 1-1: new high-speed USB device number 2 using ehci-pci
[    1.633128] usb 1-1: New USB device found, idVendor=8087, idProduct=0024
[    1.633134] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    1.633458] hub 1-1:1.0: USB hub found
[    1.633518] hub 1-1:1.0: 6 ports detected
[    1.745151] usb 2-1: new high-speed USB device number 2 using ehci-pci
[    1.877632] usb 2-1: New USB device found, idVendor=8087, idProduct=0024
[    1.877642] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    1.878143] hub 2-1:1.0: USB hub found
[    1.878251] hub 2-1:1.0: 8 ports detected
[    1.911482] irq 16: nobody cared (try booting with the "irqpoll" option)
[    1.911553] CPU: 3 PID: 0 Comm: swapper/3 Not tainted 3.16.0-4-amd64 #1 Debian 3.16.7-ckt11-1
[    1.911557] Hardware name: CompuLab Intense-PC/Intense-PC, BIOS CR_2.2.0.400 X64 12/12/2013
[    1.911560]  ffff8802356ef6c4 ffffffff8150b405 ffff8802356ef600 ffffffff810bd24d
[    1.911568]  ffff8802356ef600 0000000000000010 0000000000000000 ffffffff810bd771
[    1.911574]  0000000000000000 0000000000000000 0000000000000010 0000000000000000
[    1.911579] Call Trace:
[    1.911583]  <IRQ>  [<ffffffff8150b405>] ? dump_stack+0x41/0x51
[    1.911606]  [<ffffffff810bd24d>] ? __report_bad_irq+0x2d/0xc0
[    1.911614]  [<ffffffff810bd771>] ? note_interrupt+0x241/0x290
[    1.911622]  [<ffffffff810baf91>] ? handle_irq_event_percpu+0xa1/0x190
[    1.911629]  [<ffffffff810bb0b8>] ? handle_irq_event+0x38/0x60
[    1.911636]  [<ffffffff810be2b3>] ? handle_fasteoi_irq+0x83/0x150
[    1.911646]  [<ffffffff810150cd>] ? handle_irq+0x1d/0x30
[    1.911653]  [<ffffffff81514379>] ? do_IRQ+0x49/0xe0
[    1.911660]  [<ffffffff8151222d>] ? common_interrupt+0x6d/0x6d
[    1.911662]  <EOI>  [<ffffffff8108ad3d>] ? __hrtimer_start_range_ns+0x1cd/0x390
[    1.911679]  [<ffffffff813ddfa2>] ? cpuidle_enter_state+0x52/0xc0
[    1.911686]  [<ffffffff813ddf98>] ? cpuidle_enter_state+0x48/0xc0
[    1.911694]  [<ffffffff810a7fa8>] ? cpu_startup_entry+0x2f8/0x400
[    1.911701]  [<ffffffff81042cff>] ? start_secondary+0x20f/0x2d0
[    1.911704] handlers:
[    1.911768] [<ffffffffa00884d0>] usb_hcd_irq [usbcore]
[    1.911869] Disabling IRQ #16
[    2.009505] usb 1-1.3: new full-speed USB device number 3 using ehci-pci
[    2.053521] ata5: SATA link down (SStatus 0 SControl 300)
[    2.065543] tsc: Refined TSC clocksource calibration: 2195.013 MHz
I cannot upload files with .txt or .log extensions so I'm linking to the full dmesg output and to the output of "cat /proc/interrupts":
http://pastebin.com/aWCEnT1B
http://pastebin.com/zdfhRBw8
I'd appreciate any help on this. Thanks.
Re: irq xx: nobody cared (try booting with the "irqpoll" opt
Forwarded to the Linux expert...
Denis
Post by Denis »
Try to boot LiveUSB with LinuxMint17.1 and compare mouse behaviour and performance to your Debian 8 installation.
I personally didn't encounter such issues, so may be it's related to Debian 8 only.
mostacholoco
Since I updated to Debian 8.1 (from Debian 8.0) I haven't faced this issue again. At least, I've booted around 20 times and I haven't seen this happen not even once. So I'd say for now it seems to be fixed. Thanks.
